Rattle can satin finish
12 posts • Page 1 of 1
Postby Thxcuz on Mon Jul 02, 2012 8:59 pm
I'm painting my Murray Moterey with a satin rattle can (krylon fusion) so far so good. Is the texture supposed to feel rough or do I need to smooth it out with steel wool or something?
It looks great but feels a little rough to the touch.
No Lycra.....EVER!
Thxcuz
Re: Rattle can satin finish
Postby udallcustombikes on Tue Jul 03, 2012 12:52 am
Try wet sanding it with some 400-600 grit wet/dry paper between coats and finish with a satin clear.
Cameron
udallcustombikes
Postby big kountry on Tue Jul 03, 2012 8:44 am
udallcustombikes wrote:Try wet sanding it with some 400-600 grit wet/dry paper between coats and finish with a satin clear.
an doing that will also insure a longer life fo your paint I would go with at least 5 coats of clear
Kountry Kustoms
Nuttin Fancy
Big Dawg Eliminator
big kountry
Postby g-ratter on Tue Jul 03, 2012 3:20 pm
Is that Fusion a textured paint?
If it is not sounds like you are spraying it on a little to dry. May need to do a little heavier of a coat but not so much that it runs.
g-ratter
Postby aka_locojoe on Tue Jul 03, 2012 6:35 pm
Isn't Fusion for plastic?
Postby Thxcuz on Tue Jul 03, 2012 6:57 pm
The can says it can be used on metal....so far it looks good. The wet sanding seems to be working ok.....the color looks a little too "army green" than I like but I guess I can do red fenders or something for a pop of color.
No Lycra.....EVER!
Thxcuz
Postby outskirtscustoms on Sat Jul 07, 2012 8:32 pm
Try soaking your spray can in really hot water before spraying it. That helps the paint flow better through the nozzle and it lays down much more evenly.
Postby Thxcuz on Sat Jul 07, 2012 8:56 pm
It's been over 100 degrees here for 2 weeks. No cold cans here. I followed someone here's advice and got one of those 3 dollar trigger thingys. It made a world of difference. I was never great at spray painting but my bike looks great. No drips, no orange peel. May not be up to professional standards but it's good enough for me.
No Lycra.....EVER!
Thxcuz
Postby outskirtscustoms on Sat Jul 07, 2012 8:57 pm
Thxcuz wrote:It's been over 100 degrees here for 2 weeks. No cold cans here. I followed someone here's advice and got one of those 3 dollar trigger thingys. It made a world of difference. I was never great at spray painting but my bike looks great. No drips, no orange peel. May not be up to professional standards but it's good enough for me.
Even if it has been hot it still helps believe it or not.
Krylon Fusion
Postby QuickSand on Mon Jul 09, 2012 2:34 pm
Fusion is for plastic, the paint is thicker too. I would personally try a different enamel so you can spray multiple thin layers.
QuickSand
Postby QuickSand on Thu Jul 12, 2012 10:53 am
Got pictures of the final finish?
QuickSand
Postby Thxcuz on Sun Jul 15, 2012 8:11 am
I've been on vacation so I haven't made much progress. Hope to pick it up this week
No Lycra.....EVER!
Thxcuz
Return to BIKE TALK
Users browsing this forum: CCR, ChrisMac, Google [Bot] and 9 guests
