Xtracycle on the Kona
29 posts • Page 2 of 2 • 1, 2
Postby ricksterr1221 on Wed May 09, 2007 4:49 am
Larry wrote:They're great for haulin around chicks.
I thaught Chicks was another word... LOL
ricksterr1221
  • ICQ
Postby new_dharma on Wed May 09, 2007 8:52 am
you have gears...my Surly wasn't going to be the Xtracycle it is today, and my gearing is downright BRUTAL for commuting (for the first week or so!).
Enjoy (as i'm sure you will) the Xtracycle!
Wheel Good Bicycles
My MySpace
new_dharma
Postby cman on Wed May 09, 2007 9:10 am
thanks for the comments.
New Dharma, I am already enjoying and more so each day. The gears are nice though I only use a few. The single up front and derailier in the rear works great for a commuter.
Postby new_dharma on Wed May 09, 2007 12:57 pm
i always love the question, "What kind of bike is that?" or "What do you haul with that?"
Wheel Good Bicycles
My MySpace
new_dharma
Postby cman on Thu May 17, 2007 3:48 pm
added fenders that I found on CL for $15. Plastic Zefals- not fancy, but functional.
Better than paying $50 for a spanking new set.
Postby mastershake916 on Thu May 17, 2007 5:06 pm
I just bought an xtracycle kit with freeloaders and footsies for $150.
It doesn't have some of the mounting hardware, but I can either buy it or just use some other things.
mastershake916
Postby gravediggerjason on Thu May 17, 2007 6:57 pm
...more of us need to be usen bikes for little trips... i know it took alot for my fat back side to get out of the SUV and on to my bike ... but its so worth it ...
....and now all you have to do is throw a paddle tire on the back of that bad boy and hit the dunes .....
.......... now where did i leave that hammer .... never mind i'll beat it in with a rock.......
http://www.myspace.com/freedad
gravediggerjason
Postby cman on Thu May 17, 2007 6:59 pm
you luck dog. What a deal. There are only 3 bolts, and one nut needed to attach to the frame. You probably could buy those from a hardware store. The Front attachement plate is also needed.
http://www.xtracycle.com/front-attachme ... -p-16.html
If you have questions either New Dharma or myself probably could help. The re is a forum at Xtracycle also that could be of help
here is the owners manual
http://www.xtracycle.com/media/manual.pdf
edit----2 special nuts needed Xtracycle might sell you a "build kit" so you have the cables, bolts nuts and other items. since you saved $$ That would be the wisest choice. They aren't too far away from you either.
Postby mastershake916 on Thu May 17, 2007 11:19 pm
cman wrote:you luck dog. What a deal. There are only 3 bolts, and one nut needed to attach to the frame. You probably could buy those from a hardware store. The Front attachement plate is also needed.
Thank you for your advice.
I think I might be about to use part of a kickstand instead of a front attachment plate, but I'll have to try that out. With the rest of the mounting hardware hopefully I'll be able to find that at a hardware store.
mastershake916
Postby cman on Thu May 17, 2007 11:33 pm
What bike are you putting it on?
Postby new_dharma on Fri May 18, 2007 1:20 am
mastershake916 wrote:I think I might be about to use part of a kickstand instead of a front attachment plate, but I'll have to try that out. With the rest of the mounting hardware hopefully I'll be able to find that at a hardware store.
bolt-on kickstand mounting plate should work...i had to modify how i mounted mine...the Surly's chainstay bridge is too close to the bottom bracket. I would have been ok if I ran a derailer, but doin' the singlespeed thing I needed to adjust back...at the time I never thought about a kickstand plate.
Wheel Good Bicycles
My MySpace
new_dharma
Postby mastershake916 on Fri May 18, 2007 2:33 pm
cman wrote:What bike are you putting it on?
It's going to be put on a cannondale M500.
It's a light and durable frame from what I've heard, mine seems to be from the early 90's.
Also, thanks new dharma.
mastershake916
my xtracycle
Postby moleman on Fri May 18, 2007 10:23 pm
Well I retired my RatRod fixed gear cruiser, and moved my xtracycle kit from the mountain bike to the cruiser. What an improvement, lower, handles better, and I used these cool unbreakable wheels!
moleman
Re: my xtracycle
Postby gravediggerjason on Fri May 18, 2007 10:30 pm
moleman wrote:Well I retired my RatRod fixed gear cruiser, and moved my xtracycle kit from the mountain bike to the cruiser. What an improvement, lower, handles better, and I used these cool unbreakable wheels!
thats slick its gotta real fifties long trunk look, or maybe a 59 elcamino
and i am in love with the mags!
gravediggerjason
Previous
Return to THE OTHER BIKES
