BIKE Identfication Help.
19 posts • Page 1 of 2 • 1, 2
Postby cman on Mon Nov 30, 2009 11:48 am
Starting this to help ID bikes. This post will contain links to serial number datatbases, pictures and anything else that will help to ID your old bike. This will be a work in progress so PM me any info you have that may help. Most links will be for outside sites.
1. Find the serial number on the bike. Locations- under BB, dropouts, headtube, seatpost clamp.
Serial Number Databases
2. Look for a brand name on headbadge or chainguard. The brand name is not always the manufacture.
Manufacture/Brands
3. Sometime looking at pictures or catalogs may help.
Catalog and Picture Databases
4. Or look for characteristic on the bike to help find manufacture. Pics of dropouts, forks, badges, seat cluster
Bike frame characteristics
Re: BIKE Identfication Help.- Serial Numbers
Postby cman on Tue Dec 01, 2009 8:51 pm
ScwhinnCruiser serial number lookup VERY Cool. Automatically computes for you and even tells when it may be two different years.
Scwhinn Serial Numbers
Columbia Serial Numbers
Huffman Serial Numbers- compiled at thecabe
Huffy Serial Number decoding
Murray Serial Numbers- compiled at thecabe
Raliegh Serial Numbers- Most often a Sturmey Archer hub dating is faster.
CCM Serial Numbers
Colson
Re: BIKE Identfication Help.- Who Made It?
Postby cman on Tue Dec 01, 2009 9:33 pm
Manufactures like Shelby, CWC and Murray made bikes for Sears, Montgomery Wards, etc.... Look for Brand names on chainguards and headbadges then find the manufacture below.
Shelby
- Hiawatha (years)
CWC
-Hiawatha (years)
Murray
-Sears
-Elgin
-Hiawatha
Westfield
-Columbia
-Elgin
Re: BIKE Identfication Help- Catalogs and Picture Database
Postby cman on Tue Dec 01, 2009 9:36 pm
Catalogs and Reference pics
Picture Database Search Type in Brand, model etc at oldroads.com
TR Findley's Schwinn Catalogs
Bicycle Chronicles-Schwinn
Schwinn Cruisers
Vintage Columbia's
J.C. Higgins info small amount
Nostalic.net Pictures galore , Pictures galore 2
Pre 1920 Bikes
Literature , Literature 2
Badges
Re: BIKE Identfication Help.- Bike Characteristics
Postby cman on Tue Dec 01, 2009 9:43 pm
Pictures of tell-tale signs of manufacture- I need detailed pictures of dropouts, seat cluster, forks, headbadge etc...
Example Murray dropouts are pointy. {PIC}
Postby deorman on Tue Dec 01, 2009 9:56 pm
Here's typical 50's-early 60's Columbia dropouts, kickstand bracket, and continuous top tube, courtesy of Maddogrider's rrbo4 entry.
Postby NLCTVWguy on Tue Dec 01, 2009 11:23 pm
So many bikes of the types we are interested in have lost identifying marks. It does become necessary to do this kind of cross-referencing to identify what it is that you have found.
Once these basics are complete, hopefully we can get into some specifics within brands that will help identify years of manufacture more closely. For example, nearly all manufacturers changed their metal headbadges to foil stickers at some point in the later years of American production or as Taiwan or Chinese production begins. My own pile of Columbia frames shows a few different styles of headbadges as well as frame construction.
Some little bits of knowledge I've picked up over the years:
Schwinn was unique in their "Electro-forged" frame construction that produced the smooth curves of the tubes meeting the head tube.
Other joints made on the bike may be rough, but the frame head is always smooth and rounded. Some of the 10-speed bikes of the classic era, however used Japanese frames (Panasonic built) and these would be lugged frames (typically LeTour and some World or Traveler models).
Columbia made bicycles other than lightweights often feature that distinct rear hoop behind the seat post, as shown in the above picture. The only other example I know of for this arched top chainstay design is on the Vista bicycles. You can see that design on a Vista Torino 500 20" bike on my site: http://www.bareiss.net/bikesale.html
Ross bicycles (Chain Bicycle Co. of NY) often use a twin top tube design. Most of the boys 20" models used this, except the chopper-style Apollos. This design extends the top chainstays all the way to the headtube, and a second pair of cantilever bars runs parallel below these. Multi speed models up to '73 may have a shifter bracket welded under the top tubes. Ross Barracudas are an example of this style.
Columbia used different brand hubs on the same model bikes. I have had several ladies Columbia Sports 3's, mostly with Sturmey Archer AW hubs, but 1 had a Shimano coaster 3 hub. All these bikes appeared to be 100% original.
Huffy built bikes for the Grants department stores. I have examples of identical components and frame designs on Huffy-badged and Grants-badged bicycles. Huffy at one time also sold "The Wheel" and other "rail" type 20" chopper bicycles to Sears. These and the more common Murray bikes may be badged as Free Spirits.
Murray built many bikes that ended up with other brand names. A friend owns a totally original 1959 26" men's cruiser badged as a "Fleetwing" with Murray "M" decals on the seat post and Cleveland Welding marks on the bike in various places.
Coaster hubs: this is better documented in other places, but a quick summary of the common Bendix hubs is always helpful. By 1982, the Bendix hubs seem to have been replaced with Shimano coasters. Bendix 76 hubs are used from late 76 on (1977 up models). Bendix 70 hubs appear in late 1970 for 1971 to 76 models. Prior to that, there are different versions of the Red Band hub. The RB2 model was in use from 1966 or 67 to 1970. There is also a RB "Junior" hub made concurrently to these for children's bikes, but I do not have firm production dates on these.
When dealing with any "unknown" bike, it's always helpful to take apart major assemblies and search for casting info or engraved dates or manufacturer codes. For example, a Schwinn one-piece crank will have a date code forged right into it. Early models (mid 50's or earlier) may only say "AS&CO". Later ones, like the crank on my workshop table right now give the date code this way: SA 6 69 , a June 1969 crank. The SA as I understand it means "Schwinn Ashtabula", Ashtabula being the company that actually did the forgings for Schwinn for their cranks, forks, and stems. Likewise, with many components, date codes can be found or decoded to narrow down the build date of the bicycle. Handlebars, cranks, forks, pedals, tires, hubs, stems, rims, and sometimes even bearings can give up date codes to help determine what it is you have found.
This looks like it will be a valuable tool to the forum. Hope lots of good info lands here. We're off to a good start.
--Rob
--My Other Car is a Schwinn--
NLCTVWguy
Postby M.Martian on Thu Nov 04, 2010 11:37 pm
Here's a project I've been wanting to do since I started learning about these old bikes.
Springer ID and picture gallery
http://gallery.me.com/mark.martinez#100150
Hooligans B.C. of Sacramento
Rolling Relics - Ride Vintage
M.Martian
Postby kngtmat on Mon Dec 27, 2010 12:21 pm
Serial number positsion, does the position of the serial number have a meaning of what company made the bike because I have heard the head tube, dropouts and under the bottom bracket but what about if the serial number is on top of the bottom bracket since I have never heard of them being on top and the Western Flyer we just got has it there?
kngtmat
Postby deorman on Wed Jun 22, 2011 9:34 pm
@ NLCTVWguy, Vista is also a Westfield product. :|
Postby eparsons on Mon Oct 24, 2011 6:04 pm
who made pre war western flyers
eparsons
Postby thejosher on Sun Jan 29, 2012 7:36 pm
Hi, I recently picked up this bike from my mom's house after my parents divorced recently. I would like to know what year this bike is. I know that it is a AMF Roadster, that's about it. Any information about this bike would be helpful. Thanks!Image
thejosher
Maybe i can find out by the coaster brake.
Postby chainwhipped.jeff on Sun Apr 22, 2012 10:49 pm
i have a 26" cruiser/boardtrack style bike. Ive looked ages for the serial on the web. The one hint i do have is that its got a New Departure Coaster Rear Model D Hub? ideas?
ChainWhipped \m/
chainwhipped.jeff
Postby deorman on Mon Apr 23, 2012 5:34 am
Having a New Departure model D is not much use in identification. Kind of like saying your car has Michelin tires.
Postby gcrank1 on Thu May 03, 2012 7:07 am
You are going to probably have to go through a bunch of pics on this site, say, in the Gallery section, and identify what the frame is. Some frames where made by one company and badged as several, but you can likely figure out the frame maker anyway. If you can post a pic somebody can tell you what it is, but you miss the fun of checkin' out all the great pics.
gcrank1
Return to HOW TO
Users browsing this forum: Walker and 6 guests
