lowering the rear of a bike, for free with no welding.
43 posts • Page 3 of 3 • 1, 2, 3
Re: lowering the rear of a bike, for free with no welding.
Postby Meeba on Sun Aug 28, 2011 3:01 pm
My son gave me a beat up mongoose mountain bike (cheapo kind) and I am stripping it down for reusable parts, like bearings etc. Anyway, as I am looking at it i see that the suspension has these braces to it that would work same as the brake pad idea. I thought of this post as soon as i saw these.
I was chasing a dream,but tripped over reality and bust my head on the truth
B607 wrote:
By the way...A woman with tons of stuff is a hoarder. A man with tons of stuff is a collector.
Meeba
Postby thebearded1 on Sun Aug 28, 2011 5:42 pm
wow this is a great idea. I really wanna do this to my bike but add in suspension somehow
thebearded1
Postby Meeba on Sun Aug 28, 2011 6:30 pm
Here it is on my mock up/ test 20" bike. I also bent some 26" forks to help lower the front. All stuff that I learned here. Thanks guys!!!
Meeba
Postby Meeba on Sun Aug 28, 2011 6:47 pm
Here are some closeups, bare frame though, first test fit
Meeba
Postby snydur on Mon Sep 05, 2011 12:14 am
^^that looks sick! i finally got my hands on two pairs of honda pads yesterday. theyre already long gone so now they need some age. hmmmm, now i need a bike :mrgreen:
i hate "slow"
snydur
Postby Meeba on Mon Sep 05, 2011 1:29 pm
Thank you. I got the idea from you and ran with what i had available. The rear fender.....well, I always wanted one to have that look and i ended up with it by accident. I have a couple other ideas I want to work into it over the winter months.
Meeba
Postby iven on Mon Sep 05, 2011 8:55 pm
so simple yet genius..
all you really need is two chunks of metal and a drill,grinder..
you could cut a notch in the hole you put the axle in to make it look like a dropout..
just an idea..
iven
Postby kingfish254 on Mon Sep 05, 2011 9:53 pm
It seems like you could also cut some horizontal slots into the top axle hole so that you could still be able to adjust the wheel for chain tightening.
Postby ozzmonaut on Sun Oct 02, 2011 12:02 am
I found these at the salvage yard on thursday. I don't know what they were originally, but they look like they'll work great for this. All of the holes are the same distance apart, so as long as you have a hole near the dropout that is close to the same distance as these holes are from each other, it will be fully adjustable. I'm going to cut the ends so that the long slots will be extra-long dropouts. These are thicker than normal dropouts , so they will definitely be strong enough to use for this purpose. They are about 3 1/4"x 4"Image
ozzmonaut
Postby ozzmonaut on Sun Oct 02, 2011 12:23 am
Meeba wrote:Image
This one will need an extra hole drilled and attached somewhere on the fork to avoid pivoting. Especially with the way fork angles are.
ozzmonaut
Postby Meeba on Sun Oct 02, 2011 9:58 am
[/quote]
This one will need an extra hole drilled and attached somewhere on the fork to avoid pivoting. Especially with the way fork angles are.[/quote]
Yes. It is just a test fit for now, once i figure where i want it to sit, then i will make the holes or stops to keep it from pivoting. thanks though.
Meeba
Postby c.p.odom on Sun Oct 02, 2011 4:12 pm
ozzmonaut:
What you found are the spring plates from and old fashioned spring loaded garage door.
“I am easily satisfied with the very best.”
Winston Churchill
c.p.odom
Postby ozzmonaut on Mon Oct 03, 2011 4:40 pm
c.p.odom wrote:ozzmonaut:
Awesome, thanks. I've never had a house with a garage, so I definitely never would have put that one together.
ozzmonaut
Previous
Return to HOW TO
