Looking to make a bedix hub skip tooth so I'm looking for an even number tooth (20, 18 maybe?)bendix sproket. I will cut off every other tooth.
It's for the build off so hopefully I can find something soon. Let me know what you have.
Rear bendix sproket
7 posts • Page 1 of 1
Rear bendix sproketLooking to make a bedix hub skip tooth so I'm looking for an even number tooth (20, 18 maybe?)bendix sproket. I will cut off every other tooth.
Re: Rear bendix sproketAre you using a hub that uses a 3 tab sprocket or a sprocket that will screwon? Kevin
For other hard to find bike parts go to
http://stores.ebay.com/Bike-Parts-Unlimited http://www.bikepartsunlimited.net
Re: Rear bendix sproket3 tab
Re: Rear bendix sproketGood luck with your project but you should know that a skiptooth sprocket is wider (thicker) than a standard 1/2" pitch and the teeth are way less "pointy". I have heard of people doing this with mixed results...most complain of the chain "jumping" on the modified sprocket or of the chain coming off altogether...just thought you should know before going thru all that work/trouble...P
Re: Rear bendix sprokethmmm... interesting stuff, thanks.
what is the general consensus with running a 1/2" pitch on a skip tooth chain ring?
For the time you spend , you can get a conversion sprocket for less than $20 , email skiptooth@inebraska.com direct
Re: Rear bendix sproketthanks! I sent them an email.
Who is onlineUsers browsing this forum: No registered users and 3 guests |
