Anyone up for a tall bike challenge?
178 posts • Page 12 of 12 • 1 ... 8, 9, 10, 11, 12
Re: Anyone up for a tall bike challenge?
Postby YOUBUGME2 on Mon Oct 17, 2011 9:17 am
That is what I was thinking as well, hmm I think I have some fence tubing laying around might just be able to do this now. Thanks!
YOUBUGME2
Postby yoothgeye on Mon Oct 17, 2011 9:19 am
YOUBUGME2 wrote:That is what I was thinking as well, hmm I think I have some fence tubing laying around might just be able to do this now. Thanks!
As for what to sleeve the fork steer tube with, I found that some black iron (gas line) slides into a 1" steer tube perfectly, is very strong, and welds easily. I think it's 1/2" but I'm not totally sure, I didn't go out and buy any, I found it.
Postby ozzmonaut on Wed Oct 19, 2011 10:28 pm
Mine has been finished for a while, although not by the deadline. Anyway, I changed my strategy severely as far as correcting the fork angle. I was originally going to shorten the fork. I didn't want to sacrifice the height, so I cut the top bar. Then I put a sleeve inside the tube, and slid another sleeve over the other tube. Then I used a ratcheting strap and brute force to push the fork towards the cranks while tightening the strap. This pulled the top tube apart. Then I welded the internal sleeve, then the external. Now my fork is correct. It rides perfect now. I still don't like the skinny tires though. I'm starting on a different design next. One with a loooong headtube. The neck of these long forks is technically a weak link. It's fine for me at 175 lbs., but what if someone else wanted to ride it? Here's the before and after. Sorry about the night shot.ImageImage
ozzmonaut
Postby ozzmonaut on Wed Oct 19, 2011 10:29 pm
Wider handlebars too. Those others were kneebangers.
ozzmonaut
Postby Tommy Atoms on Mon Oct 24, 2011 5:03 pm
Wicked looking! Who cares about deadlines. The fact that we all finished what we started is all that matters.
viewtopic.php?f=21&t=16378Mr Bones
viewtopic.php?f=9&t=15396 My Builds
Tommy Atoms
Re: Anyone up for a tall bike challenge? HERES ONE
Postby TXBONE on Wed Nov 02, 2011 6:22 pm
[url]Image/url]
TXBONE
Postby yoothgeye on Wed Nov 02, 2011 7:20 pm
Nice, can you self mount/dismount on a roll?
Postby TXBONE on Thu Nov 03, 2011 12:15 pm
ya, check this link to see the mount and dismount from the triple decker tall bike. http://www.youtube.com/user/27TXBONE#p/u/6/Yk5GWaUeNPE
TXBONE
Postby yoothgeye on Thu Nov 03, 2011 2:07 pm
As soon as that spooky tooth hit the ground I knew the sound! haha It use to happen to mine all the time, but I've got it pretty well fixed now.
I was using single speed chain and my spooky tooth gear was multispeed, it was thinner and would dance around and eventually bounce out, so I swapped that ring for a single speed ring. You also have to make sure to jam it in really really tight, close to the freewheel.
Postby TXBONE on Thu Nov 03, 2011 3:53 pm
HAHA, NICE. I changed that and i dont use that any more since that video. This is what i made and installed, it works flawless even with the 2 different springs attached. I just am lazy and need to go get a single spring but i have not had a single problem yet.. haha
TXBONE
Postby yoothgeye on Thu Nov 03, 2011 5:35 pm
I like the design of that chain tensioner, simple and effective, could be adjustable too. Nice.
For your mount and dismount you might benefit from steps like on mine, and cutting off the stays on the top frame will clean the look and keep you from accidentally catching a leg on a mount/dismount.
Postby TXBONE on Fri Nov 04, 2011 4:30 pm
i like the steps you made. Interesting. As far as the back stays. my plan was to make it a wheel and a hub hooked to a cog , so its a rear wheel and have a D.C. motor turn a gear and have a chain loop them together so it spins like a ferris wheel. Then i will L.E.D. light the whole wheel.so as i ride or even when the bike is stopped the wheel will turn like a lit ferris wheel. Since i am an electrician, this bike is called the "SEA ELECTRIC BIKE". Thats why i have the "SEA" made out of chain on the bottom bike. THE SKY IS THE LIMIT WITH THESE TALLBIKES. i will keep posting progress pictures though when i make mods.
TXBONE
Postby yoothgeye on Fri Nov 04, 2011 4:34 pm
I will make a mount/dismount of my bike soon, with the steps it is actually very graceful, makes it look really easy (and it actually is).
Previous
Return to BUILD CHALLENGES
