Completed Bare Metal Build Off bikes
17 posts • Page 1 of 2 • 1, 2
Postby Wildcat on Fri Dec 02, 2011 10:18 pm
This thread is for the completed Bare Metal build off bikes. I figure it will be more convenient to see them all in one thread. A bunch of photos in each bike's post to highlight the whole bike and the things that make it stand out would be great.
Wildcat
Cuyahoga Crusader
Postby Wildcat on Sat Dec 03, 2011 11:12 pm
Wildcat
Re: Completed Bare Metal Build Off bikes
Postby jackdaw on Sun Dec 04, 2011 6:09 am
Chuffstah
Image Image
Thanks guys.
jackdaw
Postby Charles on Sun Dec 04, 2011 9:34 am
"METAL ELGIN"
That's the way it goes. But every now and then, it goes the other way too.
Charles
Postby Wildcat on Thu Dec 08, 2011 6:19 pm
The Elgin looks great.
Wildcat
Postby ozzmonaut on Sat Dec 10, 2011 10:57 pm
I just now saw this. I'll have mine up shortly. I need a cooler place to take pics than the kitchen.
ozzmonaut
Postby Wildcat on Sun Dec 11, 2011 6:25 am
Jackdaw, the Chuffstah pics now show up on my computer. I like the fabrication and dropout extensions. I was going to attempt that but I didn't use the fat tires.
Wildcat
Postby ozzmonaut on Mon Dec 12, 2011 8:56 pm
Okay, with work right now, taking decent outdoor pics would be almost as easy as pulling my own teeth. Anyway, here's a few indoor shots. Ignore the front door! ImageImageImageImageImageImage
ozzmonaut
Postby ozzmonaut on Mon Dec 12, 2011 8:57 pm
It said "Ignore the front door" not "ignore the front" but the "door" part was easy to miss.
ozzmonaut
Postby Wildcat on Mon Dec 12, 2011 9:03 pm
The lights, tank, and especially the seat really set it off. Nice work!
Wildcat
Postby ozzmonaut on Wed Dec 14, 2011 12:46 am
Everybody came up with great stuff. It was a good challenge and people didn't have to invest money if they didn't want to. Just required time more than anything I guess. I painted rimstrips brass color to show through the rim holes, but it's more noticable up close. I was so busy building this I didn't look at the build threads as closely as I should have. Now I'm going to go back and check them out closer. Wildcat, the gold backer on your chainring is awesome. If I remember correctly, you didn't attach it with anything. It's just held with the crank race?
ozzmonaut
Postby Wildcat on Wed Dec 14, 2011 8:14 am
Yes, it's bolted in with the sprocket on the race. The chain barely touched it at one point and it sounded like the rear hub was coming apart or the chain had a problem. I was thinking of using adhesive glue, like I used on the fender accents made from a belt, to tack the brass to the backside of the sprocket. it's thin, so it's flimsy.
Wildcat
Postby ozzmonaut on Wed Jan 11, 2012 5:10 am
I thought there were a couple more participants in this one.
ozzmonaut
Postby Tridynamic on Fri Jan 20, 2012 12:52 am
Here is a bike I made in about a weeks time over about three weeks with a drill, tin snips, chop saw, 2 grinders, welder. From scrap metal and some old bike parts. Fully slide position-able bottom bracket, solid steel triangular seat post engineered to set way back; but maintain proper balance as well as even load between the front wheel and back wheel so no wheelies here Seat post can be removed to insert a regular post for riders around 5' 5"+- or so. Or just leave it set back and slide the( special bolt on ) bottom bracket back and adjust ( telescoping ) handle bars for any reach......my goal was to make the comfort bike the way I would rather than look to other designs. 1.comfortable and 2. so that it would be able to accommodate most any size ( height ) person by ( built in ) position-ability. The bike weight is about 50 lbs due to the forward frame being rather hefty to accomplish the actual step through design. I think we( you ? ) could build one out of alloy = 35lbs or so. 26" wheels as well as with coaster brake.
pretty much finished bike. I'll probably do something else to it. what do you think?
So you have an idea?...Save it, you might need it when you grow up. Spanky...the little rascals
Pat 7,819,414
ABSTRACT 1.A multi wheeled apparatus adapted for use as a therapeutic tricycle; permitting enhanced apparatus stability and abilities providing exercise, therapeutic, and recreational advantages which particularly benefit disabled children
Tridynamic
Postby jdholmes on Tue Jan 24, 2012 11:07 pm
My uncle and I put this together in couple of weeks. And I would love to start showing it off and see what people think of it? and it is all bare metal.ImageImageImageImage
jdholmes
Return to BUILD CHALLENGES
