post trike pictures
181 posts • Page 3 of 13 • 1, 2, 3, 4, 5, 6 ... 13
Re: post trike pictures
Postby BadBalance on Sat Jul 12, 2008 12:57 am
The " Trunk " is an icechest :wink: , The seat from my grandmas Crown 24" (white vynle)
BadBalance
Postby Adapt on Sat Jul 12, 2008 1:40 am
I've had her sense I was 10...
Adapt
Postby ironrat86 on Sat Jul 12, 2008 7:58 am
nice bikes everyone heres my first trike build ImageImageImageImage
hello!
ironrat86
Postby jon on Sat Jul 12, 2008 12:36 pm
not as fancy as the rest of these but not bad for a bolt on trike.
jon
Postby Mr. Farrell on Sat Jul 12, 2008 9:27 pm
Here's the trike I'm workin on.
Mr. Farrell
Postby Markm on Sun Jul 13, 2008 8:16 am
looks like you could do a bolt on stretch to that one Mr. Farrel!!! :mrgreen: :mrgreen:
Postby Mr. Farrell on Sun Jul 13, 2008 9:35 am
Markm wrote:looks like you could do a bolt on stretch to that one Mr. Farrel!!! :mrgreen: :mrgreen:
sure could. the front half is just held on with a couple bolts... problem is the trike is for Penny and her arm reach is kinda short. I'd have to put on some extra long ape's. I'm buyin that tank from flying dingo to go on it.
I'm curious... how would you suggest doin the stretch?
Mr. Farrell
Postby Markm on Sun Jul 13, 2008 9:39 am
some sort of "sleeve". The wide cruiser bars that come back at you might work good for shorter arms...and a backwards neck..
Postby Mr. Farrell on Sun Jul 13, 2008 9:54 am
cool. i've been brainstorming. thought about completely replacing the top tube, but i dont have a welder. Penny came decided she wanted a motor trike look... so i'll probably just slap that tank on and just dress everything else up... tires, fenders, trunk etc. and change to a regular seat... with a bent seat post to give her more leg room.
Mr. Farrell
Postby Kustom Kreator on Sun Jul 13, 2008 10:56 am
You wouldn't have to do any welding to stretch that trike. All you would need to do it get two pieces of square tubing. One piece should fit snugly inside the exixting tube and the other piece should be the exact same size. Slide the smaller piece into the trike frame and drill some holes all the way through using the existing holes in the frame. This will be your "sleeve" and should be very strong. Bolt that piece on and then slide the bigger piece onto the front of the smaller piece and drill some more holes through that using the front part of the bike(the part thats currently bolted to the frame) for the drilling template. This way the front bolts hold the front part of the bike on as well as securing the extension to the sleeve. Paint and done........
This would keep the crank in the existing place. If you wanted to move the crank forward then you would have to cut the frame and do your stretch/splice between the seat tube and the crank adding a piece in the middle.
John.... more ideas than time!
Kustom Kreator
Postby Mr. Farrell on Sun Jul 13, 2008 11:02 am
awesome... thanx for the advice. sounds like a plan. :D
the welding i was referring to would be to customize the top tube. but with the tank i'll probably leave it.
Mr. Farrell
Re: trikes pictures of them
Postby erix on Sun Jul 13, 2008 11:21 am
bad news wrote:ill post the ones i have saved
That one was built in Las Vegas by a very talented car builder named Skip. Here's another of that one:
And a different one. Skip's not afraid to cut anything up...
erix
Postby JoKeR63 on Fri Jul 18, 2008 8:26 pm
Here ya go...
JoKeR63
Postby Mr. Farrell on Fri Jul 18, 2008 10:00 pm
ohhhh... that's sick!!
Mr. Farrell
Postby stephen on Sun Jul 20, 2008 8:19 am
bad news wrote:Image
Coool! A quike / quinticycle :)
'Ride like you mean it'
stephen
Users browsing this forum: ETHANSFBIKES, Rizzoguy and 6 guests
