RRBBO - Good Vibrations
53 posts • Page 2 of 4 • 1, 2, 3, 4
and on the bearings maybe try the stuff of the murray.... cups and all
PEDDLIN KUSTOMS FACEBOOK MY INTRO THREAD/PROFILE
i usually tap in with a hammer turned on its side... usually they dont fit to tight and if they do they might not be corect for the bike
Block of wood works for me everytime.
"Every day is a build off"-Not Hugo http://www.howtofixbikes.ca http://takingpictures101.blogspot.com http://freebikebook.blogspot.com
the bike is looking good .. run into the chain issue before here is a ring that works.
http://www.bikepartsusa.com/product_inf ... 01%2D98069
a krate sprocket or a clover sprocket off a 5 speed schwinn should work too
I use the wood and hammer but also made this
I've seen one better then this that had something brass (soft) instead of the washers I used. Whatever was brass fit inside the bearing cups. I can't recall what the brass part was though.
The chainring is for a coaster which requires a different width chain compared to a 5 speed chain.
The shifter is mounted to a totally different headset setup then what you have. THe original headset has a cone shape nut that that fits the shifter better. Check your collegiate.. dumpster diving since 1994
When I was a kid I used to pray every night for a new bicycle. Then I realised that the Lord doesn't work that way so I stole one and asked Him to forgive me. Emo Philips
Brilliant homemade tool Randy, thanks for the idea.
Thanks. Oh and of course it works on bottom brackets as well.
I second that..... peace, Kev. Pin-it !
For the headset or BB cups, I like the hammer and wood method.
I have switched to using a dead blow hammer though, lead shot in the head, hard rubber face. No bounce. Once you get accurate it is pretty much a one shot install (it helps to have some inner rage though). It don't make her a bad girl, but it does make her popular.
I like the custom install tool but I cant weld so I will stick with the 2x4 and hammer method.
The bike looks sweet. Nice and simple ratted bike with a very classy look. Clancy
did you get the bearing issue figured out?
I've got another set of cups and bearings to try to see if that will make a difference or not. Just got to find the time to do it! I've also run into another snag. My chain is just a bit too long and when I remove a link then it's too short. Someone told me I should look into finding a half link to use. I guess I have to learn all this somehow.
Who is onlineUsers browsing this forum: No registered users and 1 guest |
