DX Klunker "It's done"
Start your build diary here.
32 posts • Page 1 of 3 • 1, 2, 3
Postby Rodland on Thu Oct 09, 2008 3:19 pm
I am in. My regular puter took a dive and I can't get my pics to download on this one. :x I got a DX, I'll have to check but I think it is a 51. I started to sand it today and found a few rust spots where it had been scratched, so I blasted those spots. Well you know how that goes, there is no stoping place. The whole bike is now blasted and ready for primer. I need to get back to getting pictures to work, so that is it for now. I just wanted my name in the hat.
My forgetter's getting better,
But my rememberer is broke.
Rodland
Re: DX Klunker
Postby necessaryevil on Thu Oct 09, 2008 3:30 pm
Is this the old 24" Dx you got from me a while back? Can't wait to see what your plans are.
necessaryevil
Re: DX Klunker
Postby Rodland on Thu Oct 09, 2008 4:50 pm
Yep. I used all the parts on the frame I had as a kid. So it was just laying around waiting for some donor parts. Still trying to get pics up. :? Dang windows VISTA
Rodland
Re: DX Klunker
Postby OUTLAW on Thu Oct 09, 2008 5:53 pm
hey, glad ya came in.
Outlaw 8)
Outlaw Bikes
BURRITO'S RULE
OUTLAW
Re: DX Klunker
Postby Rodland on Sat Oct 11, 2008 10:52 pm
OK, I got the pics loaded. But I can't remember how to get more than one to load. So here is one of four I got.
This is the frame I'll be using.
Guess I'll just edit till I get it all in. Well I don't know what happened to the color on this one :?
Here it is blasted clean. Started to just blast a few rusty scratches but it was going pretty good so next thing I know, it is all silver looking.
This is my donor, a huffy 10 speed. I got it Saturday at the Goodwill store.
Rodland
Re: DX Klunker
Postby necessaryevil on Sun Oct 12, 2008 9:29 am
Finally some pics! :D Looking good so far.
necessaryevil
Re: DX Klunker
Postby Rodland on Sun Oct 12, 2008 1:53 pm
This is what I ended up with about midnight last nite. Taped the cables up and took a test ride. Going to change some things but it is close to tear down and paint. Need a bracket for rear brake mount, change front sproket to single (5 speed) sproket, and change the handle bars to something more older. Then GET RID OF ALL THAT PINK.:)
Rodland
Re: DX Klunker
Postby OUTLAW on Mon Oct 13, 2008 11:45 am
very nice indeed
Outlaw 8)
Outlaw Bikes
BURRITO'S RULE
OUTLAW
Re: DX Klunker
Postby JoeyMac on Mon Oct 13, 2008 8:03 pm
some hipster is going to see all that pink and want to buy it off of you, haha
other than that, looking good :D
JoeyMac
Re: DX Klunker
Postby Rodland on Mon Oct 27, 2008 8:48 pm
A little update on my build. While waiting for some black cables, bear trap pedals, shiney handbrake levers, and crank, I got the wheels cleaned up, changed the chain wheel to a single one and reworked the handlebars that I want to use. Got the parts in today so final mockup should be soon. Then it will all come apart for paint. Only problem is that it has turned cold so I will have to wait for a nice day for painting. Maybe I will have some update pics soon.
Rodland
Re: DX Klunker
Postby Rodland on Sat Nov 01, 2008 9:12 pm
Well I got a lot done today. Broke it all down for paint and final parts cleaning. Got the parts cleaning done but no paint. I wet sanded the frame and went through a few spots so reprime was in order. It was to late in the day to resand and paint so that will wait until next week. I just didn't want to rush things at this point.
Rodland
Re: DX Klunker
Postby Rodland on Fri Nov 07, 2008 8:26 am
Just to let you know I'm still chipping away at this thing, but it is RAINING!! Sneak peek :wink:
Rodland
Re: DX Klunker
Postby ponytailmike on Fri Nov 07, 2008 10:15 am
that checkerboard is Kool...
did you use anything special to lay out the pattern???
ponytailmike
mike
The “bicycle” is a mechanical work of art.......unknown
“Sha-sha-sshhaa"............ Rusty Shackleford
"Expect the worst" and "Hope for the best"
ponytailmike
Re: DX Klunker
Postby Rodland on Fri Nov 07, 2008 1:08 pm
Nothing special, just 3/4" masking tape. Start by wrapping tape around the legs, one wrap next to the first one all the way up. Then remove every other one. Then go vertical, one right next to the other. Remove every other one of these. You now have overlapping tape squares which you cut around the four sides with an x-acto knife, very slight preasure on the cuter. Remove the squares you just cut around,( the ones with two layers of tape) and spray contrasting color. I sprayed the whole thing white then black after taping. Does that make any sense at all? I am one that can show you how to do something, but can't explain how I do'ed it. :oops:
Rodland
Re: DX Klunker
Postby ifitsfreeitsforme on Fri Nov 07, 2008 1:26 pm
Cheap Trick yeah!!
ifitsfreeitsforme
Return to KLUNKER BUILD OFF
