Kamelback Klunkster
Start your build diary here.
19 posts • Page 1 of 2 • 1, 2
Kamelback Klunkster
Postby ej599 on Sat Oct 18, 2008 6:43 am
Well, I have this blue 67' speedster or this red 71' racer, a S.A. 3 speed hub and a set of NOS 24" s-7 hoops which I've located some tires for. Now all I need is spokes. I was told there 9-3/4" but if someone has a spoke chart and could verify that, I'd be grateful.
ej599
Re: Kamelback Klunkster
Postby Markm on Sat Oct 18, 2008 2:35 pm
I have a calculator but need to know:
number of spokes
hub size( 67mm, 63mm, 48mm, 44.5mm, 40mm, or 34mm)
spoking pattern ( 3X or 2 X)
havent tried this yet....looks confusing...
EDIT: just need to know spoke count and pattern, 3X or 2X
Postby Markm on Sat Oct 18, 2008 2:45 pm
I tried: 24 in. rim, 32 spokes,SA hub (67mm.), 2X pattern and got 233mm. which is about 9 3/16 ths...If I did it right... Ill practice while waiting for your spoke count... :mrgreen:
Postby ej599 on Mon Oct 20, 2008 6:08 pm
36 spokes.
ej599
Postby Markm on Sat Oct 25, 2008 8:52 am
9 7/16 with 3 X pattern...
Postby ej599 on Sat Oct 25, 2008 1:27 pm
Thank you sir!
ej599
Postby ej599 on Wed Oct 29, 2008 5:24 pm
Well my tires arived from Crassley today and man are they nice! Great price too. I wrote off trying to find knobby tires for 24" S-7 wheels but these have a somewhat aggresive tread. Its a hybrid klunker! yeah yeah thats it! :roll: Its what I got so I guess that's what I'm using. I'm using the red bike but I may borrow the hub from the blue bike as it's a 3 speed coaster brake and will save me the chore of trying to fit brakes to the smaller wheels. That's the plan for now. I gotta get spokes.
ej599
Postby ej599 on Fri Nov 07, 2008 9:45 pm
Plan? What plan? I'm going with a locked up Bendix RB-2 from a wheel with a broken spoke in my shed. It freed up nicely.
Before:
Disassembled, cleaned, greased and restriped:
Spokes are on the way!
ej599
Postby ej599 on Sat Nov 08, 2008 5:03 pm
Uh-oh! Braze failure.
Can we fix it! Yes we can!
ej599
Postby ej599 on Tue Nov 11, 2008 6:39 am
Well I think the simple way to fix it is to remove a little paint at the weld area and then touch it up.....Heh heh! Never been one to do things the simple way.
ej599
Postby ej599 on Tue Nov 11, 2008 9:31 pm
Litlle weld on top.
Little weld on bottom.
Both sides, bottom and top! in primer too!Image
"Dehhh-you aint goin' nowhere!"
ej599
Postby ej599 on Fri Nov 28, 2008 4:14 pm
I got my wheels built although they still need truing, and my frame painted. That Dupli-Color Metal-Specs is some good spray can paint.
ej599
Postby Markm on Fri Nov 28, 2008 4:43 pm
lookin good!!! So the spoke calculator was right???
Postby ej599 on Fri Nov 28, 2008 5:01 pm
Well after I switched my hub choice from the S.A. 3 speed to the Benbix R.B 2, which is about 5/8" smaller in dia. I figured it would affect the length. So I went to one of those sights and did it myself. Thanks alot for your work anyway though! :P Sorry you wasted your time. FYI I used a 4 cross and it came out to 9-7/8". Considering that you were probably right.
ej599
Postby schwinnmesa on Fri Nov 28, 2008 5:07 pm
:mrgreen: :mrgreen: :mrgreen:
-Zach
schwinnmesa
Return to KLUNKER BUILD OFF
