Kamelback Klunkster
19 posts • Page 1 of 2 • 1, 2
Kamelback KlunksterWell, I have this blue 67' speedster or this red 71' racer, a S.A. 3 speed hub and a set of NOS 24" s-7 hoops which I've located some tires for. Now all I need is spokes. I was told there 9-3/4" but if someone has a spoke chart and could verify that, I'd be grateful.
![]() ![]() Dumpster divin' since 2nd grade.
Re: Kamelback KlunksterI have a calculator but need to know:
number of spokes hub size( 67mm, 63mm, 48mm, 44.5mm, 40mm, or 34mm) spoking pattern ( 3X or 2 X) havent tried this yet....looks confusing... EDIT: just need to know spoke count and pattern, 3X or 2X Pack Rat-Rodder
Re: Kamelback KlunksterI tried: 24 in. rim, 32 spokes,SA hub (67mm.), 2X pattern and got 233mm. which is about 9 3/16 ths...If I did it right... Ill practice while waiting for your spoke count...
Re: Kamelback KlunksterWell my tires arived from Crassley today and man are they nice! Great price too. I wrote off trying to find knobby tires for 24" S-7 wheels but these have a somewhat aggresive tread. Its a hybrid klunker! yeah yeah thats it!
![]() ![]() ![]() ![]() Dumpster divin' since 2nd grade.
Re: Kamelback KlunksterPlan? What plan? I'm going with a locked up Bendix RB-2 from a wheel with a broken spoke in my shed. It freed up nicely.
Before: ![]() Disassembled, cleaned, greased and restriped: ![]() Spokes are on the way! Dumpster divin' since 2nd grade.
Re: Kamelback KlunksterUh-oh! Braze failure.
![]() ![]() Can we fix it! Yes we can! ![]() Dumpster divin' since 2nd grade.
Re: Kamelback KlunksterWell I think the simple way to fix it is to remove a little paint at the weld area and then touch it up.....Heh heh! Never been one to do things the simple way.
Re: Kamelback KlunksterLitlle weld on top.
![]() Little weld on bottom. ![]() Both sides, bottom and top! in primer too! ![]() "Dehhh-you aint goin' nowhere!" ![]() Dumpster divin' since 2nd grade.
Re: Kamelback KlunksterI got my wheels built although they still need truing, and my frame painted. That Dupli-Color Metal-Specs is some good spray can paint.
![]() ![]() ![]() ![]() ![]() Dumpster divin' since 2nd grade.
Re: Kamelback KlunksterWell after I switched my hub choice from the S.A. 3 speed to the Benbix R.B 2, which is about 5/8" smaller in dia. I figured it would affect the length. So I went to one of those sights and did it myself. Thanks alot for your work anyway though!
