Kansas Fried Cruiser... more stuff 7/09/09
71 posts • Page 2 of 5 • 1, 2, 3, 4, 5
Re: Lawrenceburg Flyer... my first build
Postby Galtbacken on Wed Oct 22, 2008 3:03 pm
Really like that chainguard! Looks good!
"Dä ä aldri kört!"
-G. Levin
Galtbacken
Postby Ratfink1962 on Thu Oct 23, 2008 6:49 pm
Thanks guys!
The chainguard kinda scares me! I remember as a kid getting my pants stuck in the crank. And after thinking about it for a little bit it seems that my leg is probably no match for the angle of those cuts, so you could actually call the chainguard the meatgrinder!!
It does clear the crank arm, now just gotta see if it will clear my leg :mrgreen:
---Mitch aka Grillmaster Mitch.... you know....... the guy that burns the Hot Dogs!
My first Rat build>>> Kansas Fried Cruiser
Midwest Bicycle Swap Meet
Ratfink1962
Postby ExtraBlaze on Fri Oct 24, 2008 12:43 pm
BrigmasterA wrote:
ExtraBlaze wrote:That chaingaurd is blazin hot.Nice job.
I agree. It would look right at home on your higgins, blaze. :mrgreen:
Right?!
"....................." -The Stig
ExtraBlaze
Postby Ratfink1962 on Wed Oct 29, 2008 6:44 pm
I scrounged up a cool old lamp, not sure if it will be headlamp or taillamp, but Im gonna use it one way or another.
It has a cool fluted lens, that probably wouldnt work too well as a headlamp, Ill either switch it over to clear or red glass. And Ill have to modify it to run some high intensity LED's
Ratfink1962
Postby Ratfink1962 on Fri Feb 06, 2009 9:32 pm
Just an update...
Some things came up and the project got sidelined, but since things are finally settling down I should be able to get back on it.
I did get a replacement rim from LocoJoe, thanks again! and I did manage to get them powdercoated a flat black, I even managed to get both wheels relaced, but still need to true them up.
The dream of powdercoating the frame and other parts is not to be... After getting the rims done it turns out to be too expensive, even with a buddy doing the work! So... Going a different route. Using some paint and other stuff to come up with a "different" finish. I would post a pic of my progress, but im not exactly sure of how its gonna look but it should be "different" for sure.
Ive been thinking of how Im gonna make the tank, and at first I was leaning towards making a styrofoam plug, then fiberglassing over it, and then dissolve the foam using solvents... but im not a big fan of working with glass, so Im probably gonna end up just making one out of sheetmetal using a buck. I dont have a shrinker so im gonna have to cut and weld the corners, but it shouldnt be too bad.
Ratfink1962
Postby Uncle Stretch on Fri Feb 06, 2009 10:36 pm
Nice work and really good ideas :mrgreen:
Uncle Stretch
Postby jre0123 on Fri Feb 06, 2009 10:52 pm
FYI that light is a 1928/29 Model A Ford cowl light.
jre0123
Postby rgallen on Sun Feb 08, 2009 7:18 am
Hey Dude, this is so weird. When you said maybe some chainguard mods, I had this thought come into my to do exactly what you did. That's scary. They say great minds think alike. I say greater minds put those thoughts into reality. I guess you win.
Great work and kool bike. Lets see more.....
rgallen
Postby Ratfink1962 on Sun Feb 08, 2009 1:20 pm
jre0123 wrote:FYI that light is a 1928/29 Model A Ford cowl light.
Cool deal, thanks for the info... I wasnt sure what it was originally, since I found it in a junk pile.
rgallen wrote:Hey Dude, this is so weird. When you said maybe some chainguard mods, I had this thought come into my to do exactly what you did. That's scary. They say great minds think alike. I say greater minds put those thoughts into reality. I guess you win.
LOL, its all good! Give it a shot, it really wasnt that hard to pull off. Just some tubing scraps welded in at at angle.
Regarding the finish... has anyone ever seen a bike that was finished out with heat? I know it sounds strange, but when the steel is heated up to a certain point it will change colors, kinda like a deep blue color fading into yellow. Well thats what Im planning. Ill post up a few pics later to show what Ive done so far to maybe explain it better.
Ive been reading the posts about using salt and vinegar to speed up the rust process, which I may use. But I also wanted to ask if there was anyone that has tried other chemicals, acids, etc. on bare metal to get it to change colors... etc. I read something a while back about a electrolysis process that changes rust to a black oxide.
Ratfink1962
Postby Schwinnspastic on Sun Feb 08, 2009 2:28 pm
this is a cool build....chop chop the gaurd look killer, nice mod
link to intro
viewtopic.php?f=9&t=776
Schwinnspastic
Schwinnspastic
Postby Ratfink1962 on Wed Feb 11, 2009 9:04 pm
Ok so here are a couple of pics to explain what I was talking about above...
this is one of the forktubes...
and the chainring...
So lets hear your thoughts or opinions, good idea? bad idea?
I kinda like it, maybe not the prettiest thing, but at least its different!
Ratfink1962
Postby ExtraBlaze on Thu Feb 12, 2009 4:46 pm
O man.I'm glad this one is still alive.Can't wait.
ExtraBlaze
Postby ej599 on Thu Feb 12, 2009 9:56 pm
Looks good like that. You gonna clear it?
ej599
Postby socal_jack on Thu Feb 12, 2009 11:46 pm
Felt used to make a cruiser completely finished like that, called it raw or something but the frame looked really good like that. I think some other BMX companies used to do it also, think I have a set of DB bars like that somewhere around.
socal_jack
Postby Ratfink1962 on Fri Feb 13, 2009 4:13 pm
ej599 wrote:Looks good like that. You gonna clear it?
Yes, actually the chainring is already clear coated.
Ratfink1962
