Blackened (7-21, update)
26 posts • Page 1 of 2 • 1, 2
Postby Heavy Pedal on Wed May 06, 2009 10:52 am
Cool! RRBBO4. I missed the space build-off. Lotta great bikes in that one!
I'm using what I believe to be a Columbia Sterling, because it says Sterling on the chainguard. I posted this bike a while back in the finds section, and someone said it was a Columbia. Any help with the year of this model would be great.
I'm calling it Black Sunshine after a song by White Zombie, plus I have a few cans of black to use. Don't know if I should go gloss or flat. Anyhoo, thats it. Later.
He's in the garage... putszin'.
Heavy Pedal
Re: Black Sunshine
Postby karfer67 on Wed May 06, 2009 1:48 pm
that seat is awsome good luck
N*H*F*F*
karfer67
Re: Black Sunshine
Postby blacksheep on Wed May 06, 2009 3:34 pm
Looking forward to seeing how this turns out. BTW, Black Sunshine is an awesome name for a bike. :wink: viewtopic.php?f=21&t=13367&st=0&sk=t&sd=a&hilit=black+sunshine
~ I love chainguards and full fenders. ~
blacksheep
Re: Black Sunshine
Postby Heavy Pedal on Wed May 06, 2009 11:16 pm
Gee... I guess I should have paid more attention to the build sites! :oops:
Heavy Pedal
Re: Black Sunshine
Postby Rustinkerer on Thu May 07, 2009 5:43 am
Yep, it's a mid-late 60s Columbia. I have this one, called the Rat-Ster. Been working on it sporadically for about a year. Hoping I can get a 24x3" tire out back. ~Adam Image
Rustinkerer
Re: Black Sunshine
Postby blacksheep on Thu May 07, 2009 6:54 am
Heavy Pedal wrote:Gee... I guess I should have paid more attention to the build sites! :oops:
Don't worry about it. I sure don't refer to it by that name. It's just my '62 Typhoon. :lol:
blacksheep
Blackened
Postby Heavy Pedal on Fri May 08, 2009 12:12 am
Blacksheep, thanks for the feedback, but I'm gonna go with my second choice, Blackened, a song off Metallica's 'And Justice For All' album. When you think about it, there are alot of possibilities for the word black for a name. A few off the top of my head, Blackout, Back in Black, Black Plague....
I checked out your '62 Typhoon build. Very cool! Black and chrome!
Heavy Pedal
Re: Blackened
Postby blacksheep on Fri May 08, 2009 12:31 am
Thanks for the compliment on my bike, but you really didn't have to change the name. I was just pointing out that it was a good one. Blackened, on the other hand, is also a great song and bike name. 8)
blacksheep
Blackened (6-1, update)
Postby Heavy Pedal on Mon Jun 01, 2009 4:56 pm
So I got the whole bike disassembled. Now I start piece by piece. Decided to come up with a different seat. I had a set of seat pans that go together, but the mounting bracket was shot, so I had this older mounting bracket and thought I could combine the two.
First thing I did was sand 'em down and primer them.
Then I had to come up with a seat cover. I've done white vinyl before, so I found this scrap piece of black leather and thought it would go well with the black theme going on.
Next I needed some padding for the seat pan, so I used a big piece of cotton I found in the trash at work.
Then I cut the cotton and leather to give me enough to tuck under for the second part of the seat pan.
I then put the pan in place and bent the joining tabs down to keep it together.
Bolted the older mounting bracket on and called it done.
I apologize for my cell phone pics. Now, on to the fork. Later.
Heavy Pedal
Re: Blackened (6-1, update)
Postby Skipton on Mon Jun 01, 2009 8:52 pm
Seat looks nice!
Postby kingplinker on Mon Jun 01, 2009 9:25 pm
seat it killer. I have not done a seat like this one, but other seats I recovered, I alway use a heavy duty spray adhesive on all layers, it helps to keep things tight and wrinkle free! Cool build!
Do Unto Others
design: http://www.kingplinker.com
blog: http://kingplinker.blogspot.com
kingplinker
Postby Heavy Pedal on Sat Jun 20, 2009 2:12 am
O.K., as far as the fork goes, I wanted something different than the original. So I found an old BMX fork that fits the frame I'm using and cut 'er down.
Then I took a section of leftover chainlink fence pipe, measured the desired length and cut it in two.
I needed spacers to make the 2 pipe pieces fit better, so I cut off some sections from another scrap fork for the original fork.
After the fit, I drilled 2 holes on each side and bolted the sections together.
Then I measured (guesstamated) at the end of the pipe and drilled a hole, and hacksawed a path down for the front wheel to bolt onto.
Finished fork with angle cuts on the lower fork.
And a shot with first coat of primer.
Now that that's done, on to the handlebars.
I'm seeing alot of cool builds so far! I can't believe the number of bikes in this build! Cooool!
Heavy Pedal
Re: Blackened (6-20, update)
Postby Heavy Pedal on Fri Jun 26, 2009 1:18 pm
Got the frame sanded down and painted it flat black primer, which is the color I'm going with. Looked kinda boring, so I thought I'd add a frame insert for a tank look. I wanted it to fit perfectly in the frame, and doing this before was a pain, so I came up with another idea using powder to make my stencil.
Then I cut out my stencil and traced it to a piece of 3/4" board.
After cutting it out, I painted it with the black primer used on the frame.
Then I jazzed it up by screen printing this design on it.
Still much to do in a summer that's filling up! Later.
Heavy Pedal
Re: Blackened (6-26, update)
Postby yeshoney on Fri Jun 26, 2009 7:44 pm
Thats a great idea you came up with to make a stencil! Have to put that one in the memory bank!
Coming out slick!
Thanks, Joe
yeshoney
Postby ExtraBlaze on Fri Jun 26, 2009 7:53 pm
Very good Idea.How did it work out? :mrgreen:
"....................." -The Stig
ExtraBlaze
