  • Board index ‹ THE SCRAP YARD ‹ THE ARCHIVES ‹ ANCIENT HISTORY ‹ ANYTHING GOES BUILD OFF
poco rata - Updated - 1/11/09
Start your build off journal here!
17 posts • Page 1 of 2 • 1, 2
Postby bean on Sat Oct 17, 2009 5:12 am
I'm in. I wasn't going to to build anything for this, as I have a lot of work to do on my Ford Zephyr and a new kitchen to build.
I picked up a Huffy Big Wheel Slider and a set of wheels off a jogging stroller for 10 bucks from the dump shop this morning.
I've got a few ideas - some tubes from an old muscle bike frame and a 24" front wheel - maybe bare metal with some hand beaten copper parts?
bean
Re: poco rata
Postby Tommy Atoms on Sat Oct 17, 2009 5:58 am
This should be real cool. Ford Zephyr huhhh, They had em here in the 80's. What year is yours? got any pics?
viewtopic.php?f=21&t=16378Mr Bones
viewtopic.php?f=9&t=15396 My Builds
Tommy Atoms
Re: poco rata
Postby bean on Sat Oct 17, 2009 1:32 pm
Tommy, my Zephyr (British/Aussie) is a 59 model. Originally they had either a 4cyl or 155 cube straight 6, but mine has been fitted with a 250 cube 6, Toyota 5 speed and a narrowed rear end. It's had a lot of suspension work done as well, and sits real low. The engine is out in these pics, so it's sitting a little higher than normal.
bean
Re: poco rata
Postby bean on Sat Oct 17, 2009 8:55 pm
I was thinking of using a 24" front wheel, but it looked too big for the rears. The original front wheel was shot, so I pulled the axle out to check sizes. I also had another 20" coaster brake wheel which was pretty good except for a non-working brake.......Bingo!!.......everything fits. I fitted the axle to the wheel without bearings and cranked it up real tight. If anything looks like coming loose, I'll use a couple of spots of "MIGLock" :wink: .
I also fabbed a new rear axle and clamped it on for a mock-up shot. The seat is going to be a bit higher than the original placement. The front tire is a 20 x 3 and the rears are 10 x 2.125.
Axle
Axle fitted to wheel
Mock-up
bean
Re: poco rata
Postby deorman on Sat Oct 17, 2009 9:21 pm
8) :lol: :lol: 8)
Re: poco rata
Postby bean on Mon Oct 19, 2009 3:11 am
Did a little bit today. I removed the cantilever tubes from an old frame and brazed them onto the trike frame.
Might add this bar and make a tank
bean
Re: poco rata - Updated
Postby bean on Wed Oct 21, 2009 2:51 am
I was going to make a copper tank for this trike, so I made a paper template, then transferred the pattern to a piece of timber to make a forming block. When I test fitted the timber block to the frame, I thought it looked pretty good, so..........a timber tank it is! Just gotta do some more sanding and give it a clear coat. I'll have to find a nice piece of timber for a rear step as well.
bean
Re: poco rata - Updated - 21/10
Postby theVULTURE on Wed Oct 21, 2009 5:43 am
looking good!
that piece of wood fits up in there nicely
a wood platform in the back (like a wakeboard boat) would be cool too 8)
it's coming along!!
theVULTURE
Postby Gdcast on Wed Oct 21, 2009 6:21 am
I gotta be honest, at first I had my reserves, now I´m hooked, looking good! love that piece of timber, please keep it simple, looks great like that!!! :wink:
Wanna see my rides? :
Gdcast
Postby CYRUS on Fri Oct 23, 2009 8:59 pm
The wood looks sweet, maybe a slab of oak for the rear step, sounds very kewl...
CYRUS
Postby bean on Sun Nov 01, 2009 4:07 am
I got a bit more done today. Worked out a saddle mount for the vintage "leather" saddle I'm using (it's hard plastic) and bent and welded a couple of rear axle braces from some 12mm round I had.
I found a nice plank of Queensland Silky Oak for the rear step, and I'll probably laminate some and make a new tank.
The only money I plan on spending on this build (apart from the 10 buck purchase price) is for paint. Everything used so far has been dug out of parts/scrap metal bins.
bean
Re: poco rata - Updated - 1/11/09
Postby stretch on Sun Nov 01, 2009 8:14 am
you might wanna fix the toe and camber on the rear wheels. it appears to be pretty bad.
"My eyes are drooling!"
-Unchained
-Greystroke
stretch
Postby bean on Sun Nov 01, 2009 4:03 pm
stretch wrote:you might wanna fix the toe and camber on the rear wheels. it appears to be pretty bad.
The toe is fine, but looks a bit out in the pic cause I've built camber into the axle.
bean
Postby stretch on Sun Nov 01, 2009 4:15 pm
more stability?
-Unchained
-Greystroke
stretch
Postby jezusjonz on Sun Nov 01, 2009 5:10 pm
You know they have about outlawed the sliders like the huffy and mongoose and the adult size big wheels. They been drifting the hills in CA with them. THe last one I saw was going for over 350 bucks.
Cool trike cant wait to see it finished.
Terry
Jones and Son Headbadges..
Jones and Son Headbadges on Facebook
jezusjonz
Return to ANYTHING GOES BUILD OFF
