  • Board index ‹ THE SCRAP YARD ‹ THE ARCHIVES ‹ ANCIENT HISTORY ‹ RRB BUILD OFF #5
~ BlueX ~
60 posts • Page 1 of 4 • 1, 2, 3, 4
~ BlueX ~
Postby Skipton on Sat May 01, 2010 6:08 am
I will be using this diamond frame
This should be fun! good luck to everyone
Re: ~Blue X~
Postby XC204 on Sat May 01, 2010 7:15 am
Looks like a good starting place. See Ya on the 15th for the next Chicago ride. 27" or 26"?
Gary
lots of bikes
Tig/stick/plasma hobby welder
XC204
Re: ~Blue X~
Postby Skipton on Sat May 01, 2010 6:51 pm
Gary its got 26"
Getting started
Not the tire I will be using but a 26x1.95 FITS! :mrgreen:
This fork my need more engineering then I have time or skill for :roll:
It does look like my tank ideas will work :mrgreen:
Next up is to make a "seat post" out of parts from this
more to come Thanks Skip
Re: ~Blue X~
Postby Markm on Sat May 01, 2010 6:59 pm
Right On!!!!
That fork will work.....you'll find a way!!! :D
Re: ~Blue X~
Postby XC204 on Sat May 01, 2010 7:08 pm
Skip I have a 1 1/8 inch threaded tripple tree but it looks like the bearing cups are the same size as your's they measure 1 11/32 od if you could find the right size tube you could splice on 2 slices to the head tube. OR we could tig the cups right to the frame.
Gary
Gary
lots of bikes
XC204
Re: ~Blue X~
Postby Skipton on Sun May 02, 2010 2:46 am
Thanks guys I will make the fork work....Tig the cups did cross my mind :wink:
Re: ~Blue X~
Postby MAD MR on Mon May 03, 2010 5:04 am
The back tank is a nice idea... I'll follow this project ;)
Image>MY INTR0<Image
MAD MR
Re: ~Blue X~
Postby Galtbacken on Mon May 03, 2010 9:26 am
Yepp, I also like that tank under the seatstays! :)
"Dä ä aldri kört!"
-G. Levin
Galtbacken
Re: ~Blue X~
Postby Skipton on Tue May 04, 2010 3:18 am
MAD MR wrote:[
Galtbacken wrote:Yepp, I also like that tank under the seatstays! :)
Thanks Guys!
Update....
A few months ago got this Monark Free out of the trash :wink: got the rear tank from it
I have been reading about vintage race motorcycles alot lately got this idea
When its is done there will be a bar that come out of the seat post tube on the blue frame and conncets to Monark seatstays
my inspiration
Oh Man! this is so much fun already!
Thanks Skip
Re: ~Blue X~
Postby Hsean on Tue May 04, 2010 5:27 am
An idea for your fork issue, I had that problem many times, I avoid it by finding the right size of fork then grind the fork off the steerer so that you see the bottom half of the steerer that the forks where welded to, remove the one from the forks being used but use it to make spacers for the new steerer you cut out, this works well and makes builds look clean.
Collector of Raleighs!!
Hsean
Re: ~Blue X~
Postby Skipton on Wed May 05, 2010 2:21 pm
Hsean
Thanks for the tip sounds like a good idea
UPDATE....
I have been trying to figure out what to use for a seat post some thing with a cool shape
Then I looked at this lying on the basement floor :roll:
a hacksaw make it into this
I think this will work just fine
I know it looks like a hack job now but weld the Monark tube to the stock seat post and the Monark seatstays I think it will
all come together
Lots more to come
Thanks Skip
Re: ~Blue X~ update 5-5
Postby XC204 on Wed May 05, 2010 9:18 pm
This keeps getting better and better! Would the new seat stay look mor like the moto if you flipped it so the curve is to the back and the tube met at the stub tube in the center of the new seat post tube?
Gary
Gary
lots of bikes
XC204
Postby Skipton on Thu May 06, 2010 2:14 am
Gary I agree, I am still figuring out how it all goes together, I do think the Monark stay need to be turned around and think the center piece be cut off I do like the curve going up like this not shure I can ride it :roll: nobody said it needs to be practical :lol:
Thanks stay ratty
Skip
Postby Gdcast on Thu May 06, 2010 2:32 pm
So... where goes the wily bar? :lol:
Wanna see my rides? :
Gdcast
Re: ~Blue X~
Postby Skipton on Tue May 11, 2010 4:02 am
Just a quick update
Got the "seatpost" location figured out pics to come
I got this seat for free at a swap meet would be a little hard to ride :shock:
I do like the springs so put this seat pan on did not even have to drill new holes :D
I my or my not cover it.
Got this in the mail yesterday from TheFlyingDingo :mrgreen:
Thanks Skip
Return to RRB BUILD OFF #5
