Show Off Your Finished Huffy Cranbrook
167 posts • Page 2 of 12 • 1, 2, 3, 4, 5 ... 12
Re: Show Off Your Finished Huffy Cranbrook
Postby schertztx on Wed Nov 03, 2010 11:48 am
vanilla_gorilla wrote:theres no 26 krazes they only have the flames in 26x3 as far as ive seen
That's what i have found as well. I can tell you from experience that 26X3 flames do not fit on a cranbrook frame without a little "modification" :lol:
schertztx
Postby twistedmentality on Thu Nov 04, 2010 11:03 am
to tall or to wide ?
twistedmentality
Postby schertztx on Thu Nov 04, 2010 2:50 pm
Too wide. You have to let some air out and jam it in between the narrowest area of the chainstays to get the wheel in the dropouts then pull it tight against the back of the dropouts. Even then, if your wheel isn't exactly true, it rubs on the chainstays and I haven't even tried to put a chain on it yet. :D
schertztx
Postby Dr. Tankenstein on Thu Nov 04, 2010 5:56 pm
schertztx wrote:Too wide. You have to let some air out and jam it in between the narrowest area of the chainstays to get the wheel in the dropouts then pull it tight against the back of the dropouts. Even then, if your wheel isn't exactly true, it rubs on the chainstays and I haven't even tried to put a chain on it yet. :D
Good luck, I had to hammer the snot out of my frame. I have brand new, very true rim on there and from time to time, for no apparent reason it will start rubbing. I may add a half link, I've got room on my dropouts.
Postby schertztx on Thu Nov 04, 2010 7:46 pm
Oh I'm not going to leave mine like that, I cut some dropout extensions with the plasma the other day and I should have them welded in place and trued up this weekend.
schertztx
Postby twistedmentality on Fri Nov 05, 2010 10:20 am
i almost bought the cranbrook but the welds looked crappy and the bike was a tank so i bought the "next" cruiser.
twistedmentality
Postby Markm on Fri Nov 05, 2010 10:23 am
Postby XC204 on Fri Nov 05, 2010 11:13 am
Mark that green one Knocks me Out!
Gary
lots of bikes
Tig/stick/plasma hobby welder
XC204
Postby Markm on Fri Nov 05, 2010 11:55 am
same bike :mrgreen: :mrgreen:
added an OCC fork and paint.
Postby garagegoon on Fri Nov 05, 2010 12:00 pm
As soon as I found this site I used a Cranbrook as my first build. It has long since been parted out and divided up.
garagegoon
Postby screw_dup on Fri Nov 05, 2010 12:18 pm
screw_dup
Postby 1170TomD on Fri Nov 05, 2010 6:37 pm
StepChld wrote:Thing 1
Thing 2...although it will be changed soon (but I don't know what just yet. :wink: )
Wat kind of front hub is that??
1170TomD
Postby outskirtscustoms on Fri Nov 05, 2010 7:03 pm
Not TECHNICALLY a Cranbrook, but the Santa Fe 2 is pretty close. Only difference is the down tube is a little fatter on the Santa Fe 2.
But anyway here's mine.
Postby Bigcam59 on Fri Nov 05, 2010 8:41 pm
my Santa Fe Klunker. Close enough to a Cranbrook... 8)
Member#3009
Bigcam59
Postby aka_locojoe on Sat Nov 06, 2010 7:04 am
I think this was the first bike I ever customized years ago. Huffy but can't recall what model.
Users browsing this forum: mrflibbles and 1 guest
