lowering the rear of a bike, for free with no welding.
43 posts • Page 1 of 3 • 1, 2, 3
Postby snydur on Sat Apr 09, 2011 3:57 pm
last of of today.
on your way home, find a rusty, completely shot brake pad
clean it up
bolt it on
and in five minuites, your bike sits afew inches lower, and is a tad bit longer.
you will have to drill a hole in the"bracket" to bolt it in a second place, just so it stays
oooooor, add a spring from the bottom of the bracket to somewhere on the frame, and you can now have a full suspension bike.
i hate "slow"
snydur
Re: lowering the rear of a bike, for free with no welding.
Postby EasyRider420 on Sun Apr 10, 2011 6:45 am
thats a wicked cool idea man i got a bike that needs somethin extra i think this is it!!!! thanks again for sharing your creative juices!!
-Easy Rider
Rat on and Rat Hard.
EasyRider420
Postby snydur on Sun Apr 10, 2011 9:48 am
ive just wondered why the fronts of bikes are always lowered ,but not the back. found a solution. :mrgreen:
i hate "slow"
snydur
Postby miloziffel on Sun Apr 10, 2011 4:29 pm
Have you checked chain clearance? Great idea!
miloziffel
Postby snydur on Sun Apr 10, 2011 5:22 pm
chain clearence was my first thought honestly. but it seems to not be all that bad.
it does rub a little, but i believe thats just because there is onyl one side. once i find anouther pad, and add some washers (to mahe up for the width of the frame) it should be fine.
i hate "slow"
snydur
Postby harquahalas on Sun Apr 10, 2011 5:51 pm
This looks like a really cool idea. I wonder if it will stay in position well for riding?
harquahalas
Postby snydur on Sun Apr 10, 2011 6:28 pm
harquahalas wrote:This looks like a really cool idea. I wonder if it will stay in position well for riding?
fixed that to! i drilled a hole through the brake pad that lines up with the stock hole for the rear fender. put a grade 8 bolt through, and wallah! no longer has a pivot point.
i hate "slow"
snydur
Postby harquahalas on Sun Apr 10, 2011 6:46 pm
Perfect! All bases covered :D
harquahalas
Postby snydur on Sun Apr 10, 2011 7:19 pm
now all i got to do is find a pair of brake pads so i can do both sides, and ride this. :mrgreen:
i hate "slow"
snydur
Postby Spokeshave on Sun Apr 10, 2011 7:42 pm
I'm going to dig for a pair of junk pads -This looks like a perfect fit for my current project.
Clint Eastwood
Spokeshave
Postby snydur on Mon Apr 11, 2011 7:14 pm
i went to the store today and bought afe washers. added two washers on each side of the axle to bing the wheel over, and everything lines up prefectly. maybe even better than before. i think i have 5 bucks in this so far (bought new nuts, bolts, washers, etc)
i hate "slow"
snydur
Postby outskirtscustoms on Mon Apr 11, 2011 7:16 pm
Awesome, i got some thick metal plates from a shifter I got at a yard sale. This gives me ideas now.
Postby snydur on Tue Apr 12, 2011 5:24 pm
well this is about it, untill i can find a pair of old brake pads (harder than i thought it would be). tubes are on and it, and the bike still sits knee high at the handle bars (im 6'1") washers are on and it lines up perfectly. i put a spacer to mock up where the wheel would be when the other side is done, and everything went perfect.
previously mentioned spacer/tail light off a trailor
shorter grade 8 bolts so i dont jab my leg into the sides. and i got to admit it looks pretty dang good.
if anyone has found a pair and bolted them on, please feel free to post pictures for the rest of us. thanks :D
i hate "slow"
snydur
Postby someguy83 on Tue Apr 12, 2011 5:30 pm
Are you using the same length of chain as previous or did you have to add a few links? You gave me a great idea thanks 8)
My intro:
viewtopic.php?f=9&t=30637&p=299962#p299962
My build:
viewtopic.php?t=36020#p352337
someguy83
Postby snydur on Tue Apr 12, 2011 5:39 pm
someguy83 wrote:Are you using the same length of chain as previous or did you have to add a few links? You gave me a great idea thanks 8)
ooooh! dur. yes i did add some links. 12 to be exact (may be less if anyone else does it, cause i also took the chain off a bike with smaller sprocket)
i hate "slow"
snydur
Return to HOW TO
