Bike change: Stretch Armstrong
20 posts • Page 1 of 2 • 1, 2
Postby FLAT BLACK KUSTOMS on Mon May 02, 2011 12:36 am
(This is a project that I started and never got past the mock up!) I have been kicking around a few ideas on what kind of bike to build for this BUILD OFF #6 and I think I have a winner ! I have been collecting parts and I finally can start this thing ! I'm not sure how to mount a MULLET on it though ! LOL!
Last edited by FLAT BLACK KUSTOMS on Mon May 23, 2011 12:17 pm, edited 2 times in total.
http://www.myspace.com/flatblackkustoms
FLAT BLACK KUSTOMS
Re: New build: Project nirve.
Postby herr_rudolf on Mon May 02, 2011 4:10 am
Nirves are cool.
Hurry up, good luck, and have some fun!
Stretch Armstrong!
Postby FLAT BLACK KUSTOMS on Mon May 02, 2011 6:11 pm
I started with a beat up 20" full suspension bike.....chopping off the swing-arm ! I have built a bike similar to this idea, but it was a 26" stretch with a standard 26" frame!
Last edited by FLAT BLACK KUSTOMS on Mon May 23, 2011 12:22 pm, edited 1 time in total.
FLAT BLACK KUSTOMS
Stretch Armstrong!
Postby FLAT BLACK KUSTOMS on Mon May 02, 2011 6:28 pm
Next thing to do is get the frame in order.....Schwinn exercise bike that I had sandblasted ! I will be attaching the swing-arm to the exercise bike frame, making it as low as possible.
I went out and did a little bit of hacking/chopping and bending on the frame. This what I have come up with so far! I am going to try and use as many parts from the exercise bike as possible, such as : forks
speedometer
handlebars
cranks
pedals.....you get the idea !
This is just a mock-up, everything is just sitting. Nothing is welded!
Last edited by FLAT BLACK KUSTOMS on Mon May 23, 2011 12:29 pm, edited 1 time in total.
FLAT BLACK KUSTOMS
Re: O.G. BMX RE-VISITED!
Postby gowjobs on Mon May 02, 2011 6:54 pm
Love the old-school BMX cruisers... and knobby-tired choppers, too.
Dave "Gowjobs" McGowan
gowjobs
Stretch Armstrong!
Postby FLAT BLACK KUSTOMS on Mon May 02, 2011 7:18 pm
I switched the fork legs around so the dropouts were facing forward or up...when it is all stable and bolted together it will be sooooo low !
I will be cutting the forks & re-positioning/welding the upper fork legs ...When this is done, I can use the plate that came with the exercise bike so I can remount the speedo and make the forks secure! I think I will leave the forks with the stand and make a quick release so I can use it for a kick stand !
FLAT BLACK KUSTOMS
Re: Bike change: Stretch Armstrong
Postby FLAT BLACK KUSTOMS on Mon May 23, 2011 12:48 pm
It was a great day yesterday and I finally got to do a little work on my new project! I was able to cut and reposition the fork legs! It is still @ mock up stage, but coming together. Im not sure about the seat yet either!
FLAT BLACK KUSTOMS
Postby FLAT BLACK KUSTOMS on Mon May 23, 2011 12:54 pm
Once I get the swingarm welded on and in place, I can actually be able to sit on it and and figure out where to put the bottom bracket!
FLAT BLACK KUSTOMS
Postby FLAT BLACK KUSTOMS on Mon May 23, 2011 12:59 pm
Then I should clean my driveway! LOL!
FLAT BLACK KUSTOMS
Postby FLAT BLACK KUSTOMS on Mon May 23, 2011 9:31 pm
I cleaned my driveway.....Now it's on!
FLAT BLACK KUSTOMS
Postby yoothgeye on Mon May 23, 2011 11:45 pm
That's a radical design... the rules may have been bent a little thought. :shock:
Postby inshane64 on Tue May 24, 2011 12:01 am
rules? what are these things you speak of?
My Intro, My First Build
RRBO#6 SpringLiner Build, Finished Pics
RRBO#7 Sweet Fancy Moses
inshane64
Postby pick on Tue May 24, 2011 9:21 am
inshane64 wrote:rules? what are these things you speak of?
Behind every broken rule, is a good excuse!!
:lol: :mrgreen: 8)
My Favorite Color is Rust!
pick
Postby Dr. Tankenstein on Tue May 24, 2011 9:37 am
I think he is referring to rule #3:
3. Must use factory frame....no altering of original frame structure/geometry
So, that means that this will be the BADDEST exercise bike on the planet!
WOOOOOO!
yoothgeye wrote:That's a radical design... the rules may have been bent a little thought. :shock:
Cheers,
Postby Gdcast on Tue May 24, 2011 10:43 am
Leave rules to lawers, this is one sick ride for sure, so if you get disqualified at least you´ll end up with a mayor bad butt design! :wink:
Wanna see my rides? :
Gdcast
Return to BUILD OFF #6
