RRBBO7 HYPE UP THREAD!
1069 posts • Page 31 of 72 • 1 ... 28, 29, 30, 31, 32, 33, 34 ... 72
Re: RRBBO7 HYPE UP THREAD!
Postby Skipton on Tue Mar 27, 2012 6:52 am
kingfish254 wrote:About to go pick this up. It just might be BO7 material!
Man I would love to have one of these!
I would use the front crank and bars(flipped) but the seat would be the rear one. It would be so long and cool.
Would need to be "bent in to a pretzel" to ride :wink:
Can't wait to see what you do with it! :mrgreen:
Postby brett4christ on Tue Mar 27, 2012 6:55 am
Kingfish,
You could use heim joints to connect the sidecar to the bike, but you would have to ensure that the centerline of the heim joints are in line and parallel to eachother or it will bind when you lean. The other kink in the cog would be how the third wheel would react during a turn, especially turning toward the sidecar.
Three Nails, One Cross, & the Sins of the World!
RRB BO#7 http://www.ratrodbikes.com/forum/viewtopic.php?f=67&t=56476
brett4christ
Postby expjawa on Tue Mar 27, 2012 6:56 am
It occurs to me that if you mounted the car on a pivot, the whole assembly wouldn't be able to stand up on its own. Of course, you possibly could still use the bike's side stand. But it would be sort of like the suspension in a car (or a springer fork) - without the spring and damper, the whole thing collapses. If you wanted it to be self supporting, you'd need a spring system to allow the movement while supporting the assembly. Maybe torsion springs on the pivot. You'd probably have to have two opposing springs so that it returned it to a vertical position normally. A damper might be necessary if the system is too bouncy, but maybe not.
Also, the side car wouldn't remain truly level; the geometry might be kind of odd. Assuming it was mounted on the right side, if you lean left, the pivot point on the frame will raise up to an extent, and if you lean right it will drop. Probably not a lot, but some. How much would be based on how wide the pivot extends from the bike's centerline, and far above the bike's roll center the attachment point is. Since the roll center is at the tire contact with the ground, even mounted to the chain stay it would be a foot over the roll center.
But aside from all that, there's no reason it wouldn't work. Just make sure that you've got enough clearance for the pedal swing when you're leaned into the car.
Rick the Jawa
(Packrat & Part Hoarder)
Click here for a 3-Star Delusion...
expjawa
Postby yoothgeye on Tue Mar 27, 2012 7:04 am
expjawa wrote:It occurs to me that if you mounted the car on a pivot, the whole assembly wouldn't be able to stand up on its own. Of course, you possibly could still use the bike's side stand. But it would be sort of like the suspension in a car (or a springer fork) - without the spring and damper, the whole thing collapses. If you wanted it to be self supporting, you'd need a spring system to allow the movement while supporting the assembly. Maybe torsion springs on the pivot. You'd probably have to have two opposing springs so that it returned it to a vertical position normally. A damper might be necessary if the system is too bouncy, but maybe not.
Giving Kingfish sidecar advice, but not me? :x :mrgreen:
Postby kingfish254 on Tue Mar 27, 2012 7:06 am
yoothgeye wrote:Giving Kingfish sidecar advice, but not me? :x :mrgreen:
All you gotta do is ask. But they like me better anyway!!! :P :shock:
Postby kingfish254 on Tue Mar 27, 2012 7:14 am
I agree that these frames would make great limo stretch choppers. But I think I have seen that done a few times now. But like Python said "And now for something completely different"
Postby yoothgeye on Tue Mar 27, 2012 7:26 am
I'm the stiff shirt pastor and you're the guy who can get them free beer. :lol:
Postby brett4christ on Tue Mar 27, 2012 7:36 am
YG, I'll play nice! :D Got a question for me? I'll even answer in a PM to keep the conversation double-top-secret!!! :lol:
brett4christ
Postby outskirtscustoms on Tue Mar 27, 2012 7:55 am
Awesome, another tandem in the build off!
Postby kingfish254 on Tue Mar 27, 2012 8:23 am
outskirtscustoms wrote:
Awesome, another tandem in the build off![/quote]
Yeah, another sub-build off.
Postby yoothgeye on Tue Mar 27, 2012 8:54 am
Yeah, another sub-build off.[/quote]
So you're in 2 sub-build-offs with the same bike? No fair!
OK, I'm in the sidecar sub-build-off, so if I can find someone using a WCC Jesse James chopper frame I can be in a sub-build-of with them, and/or if I can find someone doing a military theme, I can be in a sub-build-off with them.
Who's in?
Postby yoothgeye on Tue Mar 27, 2012 8:58 am
Alright, sidecars... this has been covered in conversations on this side before and was talked about a few threads up. I have been thinking about making a hinged sidecar instead of rigid, but then you lose the ability to get up on 2 wheels lifting the sidecar into the air, which is pretty cool. But I was thinking, what if I added a linkage to the outside wheel so that when you turned/leaned right, the hinged portion would push the linkage out causing the outside wheel to turn slightly right, and when going left, the wheel would slightly turn left. It would be cool, but would it actually do anything? I mean, the back wheel is still staying in the same position...
Postby kingfish254 on Tue Mar 27, 2012 9:17 am
yoothgeye wrote:Alright, sidecars... this has been covered in conversations on this side before and was talked about a few threads up. I have been thinking about making a hinged sidecar instead of rigid, but then you lose the ability to get up on 2 wheels lifting the sidecar into the air, which is pretty cool. But I was thinking, what if I added a linkage to the outside wheel so that when you turned/leaned right, the hinged portion would push the linkage out causing the outside wheel to turn slightly right, and when going left, the wheel would slightly turn left. It would be cool, but would it actually do anything? I mean, the back wheel is still staying in the same position...
Assuming that your sidecar wheel is close to parallel with the rear wheel, I don't know if turning it would help anything or not. It would be really different if you had your sidecar wheel even with the front wheel, then it would almost have to help steer.
Postby kingfish254 on Tue Mar 27, 2012 9:20 am
Who else is planning on using a water ski in their build???? I want to be in a water ski sub-build off as well. :roll: 8) :P
Postby yoothgeye on Tue Mar 27, 2012 9:29 am
kingfish254 wrote:Who else is planning on using a water ski in their build???? I want to be in a water ski sub-build off as well. :roll: 8) :P
Maybe I'll cut up a water ski to make the seat inside my sidecar.
Return to BIKE TALK
Users browsing this forum: No registered users and 11 guests
