Rim problem..
4 posts • Page 1 of 1
Rim problem..
Postby Jimmy the Gent on Wed Apr 11, 2012 10:06 pm
I'm putting a like-new S-7 rear rim with a coaster brake on my bike; and I ran into a problem: The chain is way too loose. After a quick count of the teeth on the cog/gear in both the old rim and the new one; it appears that the S-7's cog has fewer teeth.
My question is... can I just swap the gears? They're both coaster brake models, and look pretty much identical.
Since it possibly makes a difference; the S-7 came off a Fair Lady (I think) and the old S-2 came off a Sting-Ray.
I just want to make sure before I tear it apart...
You don't need reflectors if you've got enough chrome.
Jimmy the Gent
Re: Rim problem..
Postby CCR on Wed Apr 11, 2012 10:24 pm
should swap right over, just take the snap ring off the sprocket, no need to tear the hub down.
jeremy
Re: Rim problem..
Postby Jimmy the Gent on Wed Apr 11, 2012 10:45 pm
Wow; that was fast!
Thanks!
...and thanks for the tip. 8)
Jimmy the Gent
Re: Rim problem..
Postby gcrank1 on Thu Apr 12, 2012 11:07 am
Yeah, its almost too easy.......I swap rear cogs around quite a bit to get the final ratio I want for the intended use; ie, a park bike vs a road bike or biketrail bike. A 44 or 46 front with a 19 rear is a common, and easy to pedal ratio, a 16 rear gets tough on hills. If Im tired or lazy the 16 is my top edge, and too much if I have a hill and headwind. I just changed a 46/16 to a 46/17 and am liking it.
gcrank1
Return to HOW TO
