'38 Ford Pickup
92 posts • Page 2 of 7 • 1, 2, 3, 4, 5 ... 7
Re: '38 Ford Pickup
Postby ezernut9mm on Sun Apr 08, 2012 12:43 am
sbf and cool details. you sir, are a pimp. thanks for keeping the faith.
ezernut9mm
Re: '38 Ford Pickup
Postby bicycleguy on Thu Apr 12, 2012 11:40 pm
Got a few parts at the swap meet today, 9" rear and a set of old school pie crust slicks on Ford steelies.
I <3 Welding
bicycleguy
Re: '38 Ford Pickup
Postby ezernut9mm on Fri Apr 13, 2012 10:30 pm
keep the old slicks and find some innies!
ezernut9mm
Re: '38 Ford Pickup
Postby outskirtscustoms on Fri Apr 13, 2012 10:57 pm
Or why go 289 when you could go 351
http://portland.craigslist.org/wsc/ptd/2926778058.html
Or 360
http://portland.craigslist.org/wsc/pts/2941045952.html
Or better still 460! Can you say smokey burnout? More power Ar Ar Ar.... :mrgreen:
http://portland.craigslist.org/mlt/pts/2945293462.html
Or if you wanted to kick it oldschool and spend your life savings on the rest of the parts (And the rest of your life locating them)
http://portland.craigslist.org/mlt/pts/2956939919.html
Re: '38 Ford Pickup
Postby ezernut9mm on Fri Apr 13, 2012 11:07 pm
man, those fe's are give aways. i have had lots of really good running 352 and 360 engines, but no one wants them. a well tuned one will net you about 14 mpg, but man they make good power. i am a true blue ford fe fan. and have seen some make stupid gobs of power. i think dollar for dollar the 429/460 will make more hp/tq than any other engine.
i miss my old 68 f100. it had a 360 fe with just under 50k documented original miles. ran like a raped ape and had lots of bottom end torque. loved it.
ezernut9mm
Re: '38 Ford Pickup
Postby bicycleguy on Fri Apr 13, 2012 11:27 pm
outskirtscustoms wrote:Or why go 289 when you could go 351
Or 360
My neighbor across the street has a 289 and C4 that he keeps trying to sell to me, I can get it for a good deal but I need to scrape some $ together. I'm just a broke high school kid trying to build a hot rod for cheap. Picked up a pair of goodyear's for the front and some 15" steelies today.
I <3 Welding
bicycleguy
Re: '38 Ford Pickup
Postby ezernut9mm on Sat Apr 14, 2012 12:00 am
ok, those are "innies". probably 5.5 inches wide. see how the hubcap mounting tabs are on the inside of the wheel? i call those "innies". the cap snaps inside of the wheel instead of over it. that is what i have on the front of my 61. the wider (8") wheels are harder to find, but show up on cl every once in a while. i don't think they are factory, but in the old days lots of folks had stock wheels widened for bigger tires and that is what i found for my 61.
i love your project so far man, and keep it up!
ezernut9mm
Re: '38 Ford Pickup
Postby outskirtscustoms on Sat Apr 14, 2012 8:51 am
bicycleguy wrote: I'm just a broke high school kid trying to build a hot rod for cheap.
You're on the right site. I'm broke too. If I was building one I'd go for a straight 6 or a 4 cyl Ranger motor with a 4 speed to maximize mileage. Then drive the wheels off of it. With my budget right now I'd probably be trying to put a Briggs and Stratton on it. :lol:
Re: '38 Ford Pickup
Postby SCHWINNRAY69 on Sat Apr 14, 2012 6:07 pm
Lookin' good! 8) I just finished up the 32 Ford the other day :wink:
Too bad it's only 1:64 scale :lol:
Re: '38 Ford Pickup
Postby bicycleguy on Sat Apr 14, 2012 6:31 pm
bicycleguy wrote: I'm just a broke *** high school kid trying to build a hot rod for cheap.
Being broke sucks but it also makes you more creative and I think you learn to do way more because you can't go out and buy every part that will work perfect together, you have to make it work. Started working on the frame today, That '32 looks sweet
I <3 Welding
bicycleguy
Re: '38 Ford Pickup
Postby outskirtscustoms on Sat Apr 14, 2012 7:23 pm
Too cool. I know all about getting creative due to lack of funds. Most of my builds have been built for next to nothing. I love finding new ways to use old junk.
Re: '38 Ford Pickup
Postby bicycleguy on Sun Apr 15, 2012 7:15 pm
Started on the frame...
I <3 Welding
bicycleguy
Re: '38 Ford Pickup
Postby SCHWINNRAY69 on Sun Apr 15, 2012 7:46 pm
This is a true RAT ROD! 8)
Re: '38 Ford Pickup
Postby bicycleguy on Tue Apr 17, 2012 10:04 pm
Welded the right frame rail together, took all night because I would get everything setup and ready to weld then it would start to rain for an hour then it would clear up long enough for me to lay a few beads ... Still have a bunch of gussets to add before it's done. 9 1/2" Z in the rear and 2" in the front.
I <3 Welding
bicycleguy
Re: '38 Ford Pickup
Postby bicycleguy on Wed Apr 18, 2012 9:13 pm
I <3 Welding
bicycleguy
Return to THE OTHER TALK
Users browsing this forum: Vintagebikelover24 and 7 guests
