~~"Smokin In The Boyz Room"~~ The Finale. p13
192 posts • Page 3 of 13 • 1, 2, 3, 4, 5, 6 ... 13
Re: ~~"Smokin In The Boyz Room"~~ Update #5 - 6/4
Postby yoothgeye on Tue Jun 05, 2012 7:31 am
From what I've seen in the past, to use the "sand in the tube" trick to bending, the ends must be welded closed or somehow capped so that the sand really has no way to move at all. I never tried the sand method, I've done some bending with heat, but for my seat posts I've cut and rewelded.
Postby stocksucks on Wed Jun 06, 2012 7:22 am
yoothgeye wrote:From what I've seen in the past, to use the "sand in the tube" trick to bending, the ends must be welded closed or somehow capped so that the sand really has no way to move at all. I never tried the sand method, I've done some bending with heat, but for my seat posts I've cut and rewelded.
Yep.. that's what I do too. I've never had the sand trick done succefully. I also tryed another trick: to cap the ends with water and soap inside tube, then freeze it, and then bend. But it did'nt work also...
Waste nothing, want nothing. (Burt Munro)
Hog Boys Boardtrack Racer
stocksucks
Postby kingfish254 on Sun Jun 17, 2012 12:06 pm
Anything new going on with your build?
Postby EastOfEastLos on Mon Jun 18, 2012 2:37 am
I know I could do this with the right equipment but in true rat rodder style, I'm learning by taking some lumps here and there :P I lack better equipment too, I know I need more heat, I'm not making the tube turn red at all. I'll find a way eventually 8)
EastOfEastLos.
To restore or not to restore?, that is the question...eh, it's a rat, leave it!!
My RRBO#7 Entry - 1952 24" Monark Deluxe: ~~"Smokin' In The Boyz Room"~~
EastOfEastLos
Postby EastOfEastLos on Mon Jun 18, 2012 2:41 am
kingfish254 wrote:Anything new going on with your build?
I have been workin on the bike and spending a lot of time at work too. Been hitting some road blocks with the bike but I've been able to get some good stuff done. I'll put up some new photos soon. 8)
EastOfEastLos.
EastOfEastLos
Re: ~~"Smokin In The Boyz Room"~~ Update #6 - 6/18
Postby EastOfEastLos on Tue Jun 19, 2012 12:57 am
Thank you epay! 1940's 510 DIETZ NY Fog Light to shed some light on the subject!
50's Pin Up girlie sticker from Smoopy's that I "aged" a little by beating it up a bit and some rough stripe layouts.
EastOfEastLos.
EastOfEastLos
Re: ~~"Smokin In The Boyz Room"~~ Update #6 - 6/18 Pg.3
Postby Circa Cycles on Tue Jun 19, 2012 7:14 pm
Cool stuff there 8) The pinup girl is a nice touch :wink:
Circa Cycles
Postby justride on Tue Jun 19, 2012 11:35 pm
Nice bike - I need to track down a rear rack like that - it's sweet.
Check out my BB08 build off bike, "Bar Fly" in the Traditional Builds forum!
justride
Postby EastOfEastLos on Thu Jun 21, 2012 2:44 pm
Circa Cycles wrote:Cool stuff there 8) The pinup girl is a nice touch :wink:
Thanks :wink:
EastOfEastLos.
EastOfEastLos
Postby EastOfEastLos on Thu Jun 21, 2012 2:45 pm
justride wrote:Nice bike - I need to track down a rear rack like that - it's sweet.
Thanks. I see these racks come up every once in a while on this site.
EastOfEastLos.
EastOfEastLos
Re: ~~"Smokin In The Boyz Room"~~ Update #7 - 6/21
Postby EastOfEastLos on Thu Jun 21, 2012 3:07 pm
This is what we got, a mock-up/unbolted test. I like the low slung, elongated look to the bike. Looks meaner too.
Last edited by EastOfEastLos on Thu Jun 21, 2012 11:15 pm, edited 1 time in total.
EastOfEastLos.
EastOfEastLos
Postby kingfish254 on Thu Jun 21, 2012 10:30 pm
EastOfEastLos wrote:This is we got, a mock-up/unbolted test. I like the low slung, elongated look to the bike. Looks meaner too.
I like the stance too.
I also think the big wheels behing the front are pretty cool too!!!
Postby EastOfEastLos on Thu Jun 21, 2012 11:23 pm
Aha! This photo actually shows the rear wheel after I scrubbed off the extra layer of white paint in order to re-prep and paint again. Maybe I should leave it like this then! Hmmmmm :?
EastOfEastLos.
EastOfEastLos
Re: ~~"Smokin In The Boyz Room"~~ Update #7 - 6/22
Postby EastOfEastLos on Fri Jun 22, 2012 6:00 pm
I got'n idea, I got a goood Idea :idea: ...1,000,000 points to who can name what movie thats from!
(Hint on quote: ratROD :mrgreen: )
EastOfEastLos.
EastOfEastLos
Re: ~~"Smokin In The Boyz Room"~~ Update #6.1250 - 6/22 Pg.3
Postby Peatbog on Fri Jun 22, 2012 7:18 pm
Hey, that is a cool bike. That beat up pin-up sticker is pretty cool.
It looks like your bike would look good going out on a date with Jake's bike.*
*The style is similar is what I mean. Both bikes are cool and would look good together. Oh, forget it...
