Anyone Know Where to Get "28 inch Tires/Tubes?
3 posts • Page 1 of 1
Postby Diamond Dogg on Fri Jun 29, 2012 3:26 pm
Getting this restore project soon. Fellow RRB brothers, I am having no luck locating such a size. Any ideas? Looked on the internet w/ no luck. Any advice will help. Thanks...
"Nothing a wire wheel won't fix..."
Diamond Dogg
Re: Anyone Know Where to Get "28 inch Tires/Tubes?
Postby udallcustombikes on Sat Jun 30, 2012 3:43 am
It depends on what size 28" you are looking for.
1. ISO 622-marked as a 28" is the same bead diameter as a 700c and 29er.
2. ISO 635-true 28", used on older rod brake bikes.
Most good online or brick and mortar bike shops should have or be able to get either one of those sizes.
Another 28" is the wood rim size stitched tires. Be ready to dig deep in your wallet. http://www.memorylane-classics.com had some listed last time I was looking through their parts list.
Cameron
udallcustombikes
Postby MplsCoaster on Sat Jun 30, 2012 7:58 am
Calhoun Cycle has Creme-colored Schwalbe Delta Cruisers for $19.97
http://www.calhouncycle.com/productcart ... 7p1962.htm
You may want to check the size (ISO 40-635 mm (28 x 1-1/2 in.)
Return to HOW TO
