  • Board index ‹ THE SWAP MEET ‹ WANTED
Rear bendix sproket
The place to list items you are looking for.
7 posts • Page 1 of 1
Rear bendix sproket
Postby highship on Sun Jul 01, 2012 11:10 am
Looking to make a bedix hub skip tooth so I'm looking for an even number tooth (20, 18 maybe?)bendix sproket. I will cut off every other tooth.
It's for the build off so hopefully I can find something soon. Let me know what you have.
highship
Re: Rear bendix sproket
Postby KevinM on Mon Jul 02, 2012 11:27 am
Are you using a hub that uses a 3 tab sprocket or a sprocket that will screwon? Kevin
For other hard to find bike parts go to
http://stores.ebay.com/Bike-Parts-Unlimited
http://www.bikepartsunlimited.net
KevinM
Postby highship on Mon Jul 02, 2012 2:50 pm
3 tab
highship
Postby Pappy on Mon Jul 02, 2012 6:23 pm
Good luck with your project but you should know that a skiptooth sprocket is wider (thicker) than a standard 1/2" pitch and the teeth are way less "pointy". I have heard of people doing this with mixed results...most complain of the chain "jumping" on the modified sprocket or of the chain coming off altogether...just thought you should know before going thru all that work/trouble...P 8)
Pappy
Postby highship on Mon Jul 02, 2012 6:27 pm
hmmm... interesting stuff, thanks.
what is the general consensus with running a 1/2" pitch on a skip tooth chain ring?
highship
Postby dogdart on Mon Jul 02, 2012 7:11 pm
highship wrote:hmmm... interesting stuff, thanks.
For the time you spend , you can get a conversion sprocket for less than $20 , email skiptooth@inebraska.com direct
dogdart
Postby highship on Wed Jul 04, 2012 6:01 pm
thanks! I sent them an email.
highship
Return to WANTED
