Chain and sprocket problems....
11 posts • Page 1 of 1
Postby MulhollandBikes&co on Fri Jul 27, 2012 2:07 pm
Okay, so after i put my back tire back on after painting my frame, my chain wont stay tightened like I wanted it. It keeps getting loose. Now my chain keeps coming off and locking up my sprocket..... HELP!
MULHOLLAND BIKES & CO.
(Bicycle Repair and Customs)
(===<(^v^)>o===C
MulhollandBikes&co
Re: Chain and sprocket problems....
Postby Wildcat on Fri Jul 27, 2012 3:57 pm
You adjusted the wheel back and tightened it? Make sure the chain is on the sprockets good and leave just a little slack, then tighten down the axle nuts and it shouldn't loosen up. If it's still a problem, post up a pic of it.
Wildcat
Postby clamdigger on Fri Jul 27, 2012 10:16 pm
Consider Wald 318 rear axle washers.
clamdigger
Postby axsepul on Sat Jul 28, 2012 5:02 pm
Sounds like your washers are slipping on your new paint because they are worn out. They should have a diamond cut area which will grab on to the frame. Follow this guys advice or remove the washer from another bike.
clamdigger wrote:Consider Wald 318 rear axle washers.
axsepul
Postby Peatbog on Sat Jul 28, 2012 6:30 pm
Here's one place to get 'em:
http://porkchopbmx.com/WALD-318-Serrated-Bicycle-Axle-Washer-3-8-HUWA318.htm
Or get them here at 5x the price:
http://www.bikepartsmart.com/hub-washer-rear-wald-318-serrated-3-8-318.html
Postby MulhollandBikes&co on Fri Aug 03, 2012 1:41 am
axsepul wrote:Sounds like your washers are slipping on your new paint because they are worn out. They should have a diamond cut area which will grab on to the frame. Follow this guys advice or remove the washer from another bike.
I just checked them today and they dont have the diamond studded plateing, only what appears to be little engraved swooshes. My other question is, do they go where the nut goes on the outside, or where the sprocket and axle are at on the inside? Cos when I first bought the gosh darn thing they were on the nut side not the axle side.
(===<(^v^)>o===C
MulhollandBikes&co
Postby gcrank1 on Fri Aug 03, 2012 8:44 pm
Consider what they do and the clamp down effect. You gotta keep the chainline pretty close in this, but I prefer a washer on each side of the dropout. Ive run a thinnish flat (no aggressive surface) on the inside with the agr. one under the outer nut with success. Just having the inner nut surface as a clamp point against the dropout never seemed like enough to me.
gcrank1
Postby deorman on Mon Aug 06, 2012 9:56 pm
Single speed setups are prone to this problem because the pedal pressure required to start moving a relatively tall gear is being transferred through the chain to the rear axle. Excessive tightening to prevent slippage also can eventually "wipe" or squash the dropout surface so that it's no longer flat. You gots ta have serrated flange nuts and/or (preferred) washers on the outside. Sometimes it can help to add them on the inside if your dropouts are sloppy, i.e. squashed or overly large.
Postby MulhollandBikes&co on Wed Aug 08, 2012 12:38 pm
gcrank1 wrote:Consider what they do and the clamp down effect. You gotta keep the chainline pretty close in this, but I prefer a washer on each side of the dropout. Ive run a thinnish flat (no aggressive surface) on the inside with the agr. one under the outer nut with success. Just having the inner nut surface as a clamp point against the dropout never seemed like enough to me.
My old man took a look at it and said that was the solution. Also he said that the sprocket on the wheel wasnt tight enough so the nuts on each side were going different directions instead of going the same direction. He tightened them put washers on each side, tightened it completely and now it runs like a charm :)
(===<(^v^)>o===C
MulhollandBikes&co
Postby gcrank1 on Wed Aug 08, 2012 4:02 pm
:D :D :D
gcrank1
Postby MulhollandBikes&co on Thu Aug 09, 2012 11:37 am
Thanks for the support ya'll! :D Now my BC's run can proceed this weekend.
(===<(^v^)>o===C
MulhollandBikes&co
Return to HOW TO
