Home made mudguards/fenders
17 posts • Page 1 of 2 • 1, 2
Postby smudgery on Thu Mar 27, 2008 5:06 pm
Here's how I made a mudguard/fender from fibreglass.
You could use another fender as a mould but thats too easy.
I made my own mould from mdf and varying widths of 4mm thick plywood strips.I cut the mdf to a radius a bit smaller than the wheel with the tyre.Then laid the first 80mm wide strip of plywood on using screws.
Then I glued the following plywood strips on 2 at a time with epoxy resin.I had 6 in all to take me out to the desired radius for the finished fender.The first two strips were 80mm wide the next two 70mm and the last two 60mm.
When the resin is well set go at it with your plane shaving it down to a rough outline of your mould.
After that just use some wood filler to even it up a bit and then sand it smooth.In the photo below you can see the cutout I made for the chainguard.
This is the backside of the mould with a circular cutout for a reflector
Then I put aluminium tape on the mould so I could put the releasing wax and releasing agent on.
When she's all waxed up your ready to lay up the layers of fibreglass.The best type of fibreglass cloth to use for this is called twill weave and a heavyish one.This type of weave is great for shapes which curve in more than one direction at once.
I use a trick for laying up fibreglass.First you put your piece of cloth (in this case 1m30cm x 50cm) between two sheets of polythene then mix your epoxy resin using a hardener that makes it go off slow.
Open the polythene sheets and pour your resin over the cloth (200ml was enough).Close the polythene and get an old credit card and start spreading the resin around the cloth.Like this you get an extremely even spread of resin and all the excess ends up at the edges.You can then draw cut lines on the top of the polythene (every 100mm/4inches).This method is also infinitely less messy and cutting the cloth is very easy.
Paint a thin layer of resin on the mould and then lay the strips on one at a time not forgetting to remove the polythene!!
The reflector recess needs a plug so that the wet cloth will take the shape properly,the plug needs to be waxed too so it won't stay stuck.
Let it dry for 24hours.One point I have to make at this stage is that when I had the mould made I realised that the mudguard was more than half a circle so I was concerned that it wouldn't come off anymore when it was dry so I cut a wedge out of the middle.Before cutting out the wedge I made some key plates so it would go back together correctly.With the wedge space it was possible to "break" the mould and make it much easier to remove the fender.
After that just trim it,apply body filler,sand it,drill your holes and paint it.Ordinary stays can be use to install it but I made my own.It's getting painted at the moment but when it's installed I'll pu up a foto.
Its not a cheap way of acquiring a mudguard,or an easy one,but now I know I can make any fender in any size.The possibilities for integrally moulding recesses or protusions,maybe for housing lights,makes this a potentially interesting new way to customize and also a way of answering an apparently long standing question.
Here are some photos of the finished thing
Image Image
Image Image
Paddy and Mick are walking through a forest when they see a sign saying "Tree fellers wanted".
Paddy says to Mick "Isn't it a pity there's only the two of us"
smudgery
Re: Home made mudguards/fenders
Postby CCR on Thu Mar 27, 2008 5:10 pm
NICE !! :D
jeremy
Postby Boardtrack fan on Thu Mar 27, 2008 6:35 pm
Thats awsome! :shock: A really great tutorial as well.
Boardtrack fan
Postby Rollin Double Sixes on Thu Mar 27, 2008 6:41 pm
Very nice! I can't wait to see it painted and mounted.
Rollin Double Sixes
Postby 66olds98 on Thu Mar 27, 2008 6:44 pm
Dang dude, DIY at it's finest. Now when can we all get a set?
The Sickness...
66olds98
Postby Markm on Thu Mar 27, 2008 8:29 pm
COOOOL!! 8) 8)
Postby cman on Thu Mar 27, 2008 9:12 pm
Very nice job. I added to the How to Manual at the top of the How to Forum.
Postby sensor on Thu Mar 27, 2008 9:40 pm
thats great! im kinda partial to the buck you made(i love the wood look) :mrgreen:
Postby smudgery on Thu Apr 17, 2008 2:01 pm
The finished article and yes it is actually matt black and not out of focus!!
My brother in-law Rick sprayed it for me,thanks Rick.
Image Image
smudgery
Postby cashman on Thu Apr 17, 2008 2:46 pm
Man thats cool as all git out there!!! Beautiful results. Thanks for sharing!!!
cashman
Postby ratina on Thu Apr 17, 2008 3:14 pm
Smooth as glass! no pun intended.
That looks really sharp though, nice job! I love the fender braces you made too.
Ben
Patina + Rat = Me
ratina
Postby beernpickin on Thu Apr 17, 2008 8:09 pm
sweet tutorial. by the way nice rear wheel.
I SAID NEVER TO BOTHER ME WHILE I AM WORKING IN MY LAB!!!!
beernpickin
Postby smudgery on Fri Apr 18, 2008 12:49 pm
No,no, I like the puns,especially the "sharp" one....!!
Sometimes they just come out.
Thanks for all the positive reactions,if antone ever needs any advice on using fibre-glass or working sheet metal I'd be happy to help.
I know lots of tricks and short-cuts from having been an aircraft sheet metal worker for 12 years.
There's a lot of stuff you can make with just a drill and a vice!!!
smudgery
Postby xddorox on Sat Apr 26, 2008 6:38 pm
:shock: Wow! :shock: Simply fantastic.
Postby chainwhipped.jeff on Mon May 07, 2012 12:51 am
Worked amazing
ChainWhipped \m/
chainwhipped.jeff
Return to HOW TO
