RRBBO - Fixer Adler
33 posts • Page 1 of 3 • 1, 2, 3
RRBBO - Fixer Adler
Postby outrage on Tue Feb 06, 2007 3:30 am
So finally I decided to enter this bike in the build off. It's made in Germany by Adler in the 50s, and I want to build it fixed gear with as many cheap and used parts as possible.
Nice art déco style head bagde
BTW - the topic title is German and has two meanings: fixed (gear) eagle or quick eagle!
outrage
Postby Hooch on Tue Feb 06, 2007 7:08 am
i am loving that headbadge
i am excited to see what you do with this :)
PEDDLIN KUSTOMS FACEBOOK
MY INTRO THREAD/PROFILE
Hooch
adler
Postby rockpilex on Tue Feb 06, 2007 3:00 pm
Outrage, Thats a beautiful frame I love the lugs, should be a nice fix gear project. Don't forget to post photos of your finished bike to fixedgeargallery.com and velospace.org We need more bikes like yours on this forum
Cheers,
Gareth
rockpilex
Postby outrage on Thu Feb 08, 2007 7:29 am
Here's the front wheel. Union hub (from my "hubs" cardboard box), radially laced to a Weinmann aluminum rim (from the junkyard).
outrage
Postby Clothespin n on Thu Feb 08, 2007 8:22 am
very cool wheel...can't wait to see the finish product on this project..
Kev.
Pin-it !
Clothespin n
Postby outrage on Mon Feb 12, 2007 3:47 am
now for the rear wheel: it's not easy getting a fixed gear hub if you don't want to spend a fortune on Dura Ace/Record track racing parts. So I decided to take an old Sachs Jet coaster brake hub (from a wheel I found on the roadside), take all the brake parts off, and weld the cog carrier to the hub shell. Advantage: The gear ratio can be changed, because this hub features the same sprocket system as Shimano/SA internal geared hubs.
Cog carrier (left), hub shell (right):
Parts put together:
Parts welded togehther (and filed. I am not The Big Welder :oops: ):
Spray painted silver:
The re-assembled hub:
The hub, laced to a Mavic rim, 3 leading - 3 trailing pattern:
outrage
Postby Clothespin n on Mon Feb 12, 2007 9:26 am
wow..now that's a wheel build...
that's a BIG job to tackle with welding and all!!
great work!
peace,
Kev.
Pin-it !
Clothespin n
Postby outrage on Sat Feb 17, 2007 12:37 pm
Been busy again: I visited a friend, wo has a lathe I can use (of course, he looks over my shoulder, so I don't ruin his equipment :D ). First, I had to machine the fork crown, so the race of the headset will fit. Second, I had to make the bottom bracket fit. Problem: The Adler frame doesn't have a standard BB, and they're gone out of the bicycle business in 1957 or so, so you can't go to your LBS and buy a handful of Adler BB parts. Idea: I take an old cartridge BB with plastic case and machine it to fit, and for the opposite side I'll make a ring from black nylon material.
Before: nylon material, *** bottom bracket, fork.
Fork crown with race:
Fork in the lathe:
Close up:
After: fork, BB with ring (on the left):
outrage
Postby cman on Sun Feb 18, 2007 1:19 am
Great fabrication. How gnarly is it watch those forks spin in the lathe?
Postby outrage on Sun Feb 18, 2007 6:03 am
yes, at first sight it's kind of scary...
outrage
Postby outrage on Mon Feb 19, 2007 4:05 pm
Bottom bracket pressed in. Fits like a glove:
Some nice parts: iwis chain, Shimano DX seatpost, Altenburger Synchron brakes (they came off a bike a friend disassembled to trash it - I gave 'em a shine with Nevr Dull, and they are like new!), Kool Stop Vans brake shoes, ITM quick release seat clamp, Thun headset (aluminum with needle bearings - very nice!):
outrage
Postby karfer67 on Mon Feb 19, 2007 10:58 pm
sweet brakes there buddy. i got educated by a "fixie" ridder who said that those with real brakes are p*&^%ies. i looked at him and said "thats cool lets see how good you are when your rolling along and a car pulls out in front of you and you have nowhere to go. bet at that moment you would wish you would have put brakes on your bike!"
N*H*F*F*
karfer67
Postby outrage on Tue Feb 20, 2007 2:59 am
Agree. I think its moronic to ride without brakes. And: I live in a half million city. I'm sure the police will get you if you ride without brakes. And again you wish you would have put brakes on your bike!
outrage
Postby kemmer on Tue Feb 20, 2007 11:33 am
There's nothing wrong with riding brakeless on a fixie, you can stop pretty quick if you know what you're doing. Not as fast as with a hand brake, but about as fast as a coaster brake. There's also nothing wrong with using a brake, in fact more people should. To say that only "p*&^%ies" use brakes just causes more unskilled riders to go around crashing into parked cars, enforcing the idea that riding brakeless is super dangerous. I would say that brakeless riding (by a skilled rider) is similar to poorly adjusted rim brakes or old pads on steel rims. It's a little dangerous, but it's not exactly a death wish. You might consider using just a front brake for style points, but there's nothing wrong with using two.
kemmer
Postby karfer67 on Thu Feb 22, 2007 1:39 am
exactly yea you can stop pretty quick but still. and there are a lot of newbies buying fixies and removing the brakes because it is cool before i feel they really know what they are doing.
N*H*F*F*
karfer67
