Custom Diamondback "JOKER" ~~DONE, FINISHED, CONCLUDED!~~
Nov 17, 2012
21,410
18,376
Broken Hill, Australia
Ok, first off a bit of history, through my school years I rode quite a few different bikes but kept coming back to BMX bikes, I had some Redline's, GT's and a few others but my favourite of them all and the one I miss the most was my Diamondback. For some reason it seemed just that bit more special than the others.
My Diamondback was probably a basic model but I had it for quite a while as it was a longer frame than most and I have always been on the tall side, it went through many different paint jobs and component sets, I was constantly swapping out bits and pieces for better ones that I found at the dump or swapped for with my friends or bought with my pocket money, and it even became my first modified frame, I was craving a freestyle frame as they were all the rage at the time, (even though I had no trick skills, and still don't) and any I could find or afford were too small for me, so I found an old 10 speed bike with thick seat stays, cut them off and got my Dad to separate the seat stays away from the seat tube on the Diamondback and graft in the longer piece from the road bike going along level with the top tube and suddenly I had a freestyle bike I could fit!
I like to think there is someone out there now with that frame trying to work out what model it is and what it's history is!
So Diamondback BMX's will always have a soft spot with me, but of course I can no longer fit on them standard...
Here is the donor bike for my build this year, a Diamondback Joker:
This is one of the newer heavy weight trick bikes, that have come along in the last 10 years or so. I am finding these bikes pretty regularly now and getting them for good cheap prices.
The good about this style of bike:
-Very strong oversized tube frame.
-Wide double wall 48 spoke rims with 14mm axle equipped hubs.
-U brakes that provide good stopping power.
-Super strong and simple 3 piece crankset that fits a standard American BB.
-Big beefy head stems.
-Nice seatpost clamps that grip well.
-Plenty of clearance for the readily available fat and good looking 2.4” wide tires that can also run high pressures (65-100psi) for reduced rolling resistance and great weight carrying ability.
The bad about this style of bike:
-Size: Usually far too small for an adult.
-Weight: Can be up to twice the weight of a more traditional BMX.
-Style: Boring double triangle frames.
-Gearing: Most run rather low gearing, these are slow speed trick bikes after all.
So my goal is to build a bike that addresses the bad issues and makes use of the good points too the full.
Size will be addressed with a small wheelbase extension and a large height extension.
Weight is not really an issue for me, even if I added 100lbs to this bike it still would not be anywhere near the weight of some of my other builds, and even when I am done I believe it will still weigh less than a vintage tank bike.
Style is the biggest change I will be making by adding the addition of a built in hydroformed steel tank similar to the one steel Felt bikes use, I will also being throwing in some HotRod flair.
Gearing will be fixed by switching out the small front chainwheel for a 44 tooth off an older BMX, giving a 44/13 ratio which is the equivalent of a 44/17 or 42/16 ratio on a 26” bike.
I do not believe this build will be in the running to win the build-off, that is not my goal, I just want to build a really nice bike, pretty much bomb proof and totally reliable, so it will not be over the top crazy, no custom made wheels and hugely complicated drive gearing systems, but I do intend for it to be the nicest finished bike I have done so far, all welds filed and dressed, near perfect paint, quality but not necessarily expensive components and easily capable of being comfortably ridden longer distances.
Here is an early mock up.
As you can see it is still very much BMX based, but with some vintage ratrodbikes.com ideas and style thrown in.
Pro Member
Aug 31, 2009
31,568
38,420
Historic Savannah
This is gonna be a cool mini velo build!
May 4, 2012
2,251
521
Oregon high desert
I love the look of this thing, can't to see you ride it! If I am seeing this right the top tube at the head tube is about 40inchesish:cool2::39: wait a second......... you are truly a tall man:);) :thumbsup: this bike will be incredible!
Troy
May 4, 2012
2,251
521
Oregon high desert
WOW love your design!!!!!! this will be a cool build. If I see this right the top tube will be about 40 inches!! you really are a very tall man:);)
Troy
Nov 17, 2012
21,410
18,376
Troy
37" at the front of the top tube if my mock-up is accurate, but it does go down significantly towards the back.
Thanks for your support everyone, hoping to cut it up tomorrow and start the build, if it is not raining...
Mowed the lawn today to get that out of the way, so I don't have to worry about it for a while. ;) Planning ahead...
Nov 17, 2012
21,410
18,376
Loving were you are going with this I have a massive soft spot for the old diamond backs as I had quite a few as a yound lad.
if it can rust ......let it
Not sure why Diamondbacks seem to inspire such a hold on peoples memories, but they do!
Jan 12, 2013
2,206
823
Clearwater FL
Cause Diamond backs are STRONG!
That's why you remember, couldn't kill!
Mongoose Moose, Diamond Back Elk???
Cool build Luke.
Nov 17, 2012
21,410
18,376
Need to talk to the moderators about a rule change... the rules state bike must be ridable...in your case must be able to do a freestyle trick on bike...:praise:
Grrrr... :mad:
Luke. ;)
MazdaFlyer
Like “RadioFlyer”
Pro Member
Nov 22, 2011
4,305
10,286
KS
They call those mule bikes don't they? I have a Dahon Smooth Hound with similar geometry. It is fun and nimble to ride. Good luck with your build!
