Front springfork problem
Dec 9, 2021
73
306
Hello, the concern is that the front fork of the bicycle touches the frame and damages the paint. How could this place be protected or what solution has anyone used? Thanks and good cranking.
I have put a small piece of clear flexible plastic tubing from the hardware store on the springer arm. You get a little less turning radius. Get the tubing that is a slight tight fit so it won’t move down once in place. Or, buy a piece that’s a little less tight and make the piece long enough to rest on the pivot. This is a little more obvious but they both show. The clear tubing helps hide the fix a little. You have to take apart part of the springer, that’s easy, and stretch and work it on. It may take water as a lub. It’s naturally sticky so once in place it stays. It looks factory. I gave this bike away years ago so I have no photos. It keeps the paint from chipping, which happens for sure without this fix. Even if your careful riding the fork turns when parked and then you have a chip.
Thanks mate it's a good idea!
Second that. Rubber tube or heat shrink tubing if you want low profile
