Shapely 1927 Westfield-built 28" Motobike Project
Help Support Rat Rod Bikes:
Oct 5, 2015
526
490
Kalifornia / Toes Beach
1927 Westfield-built 28" Motobike.
I bought this motobike frame &c. with damage, rust and missing parts, however, the double top-bar, special truss fork (arch or wishbone), and uncommon skip-tooth chain-ring (26-T), all caught my eye, as did the price. The condition may be what placed it into my penny-wise affordability price range. I did not know the make or model and the seller did not state, other than 19” frame for old 28” wood wheels (635mm).
I plan to add modern aluminum 28 x 1-1/2” wheels (622 mm), Velo Orange Zeppelin fenders, a vintage-looking seat/post, other parts/accessories, and finish-off with Rust-Oleum.
I believe it is a 1927 Westfield-built motobike, stamped with an “E” on the bottom (twice), the fork, and the crank. The shimmed Westfield “double-D” crank (no drive pin) also had a circle-M (too old for Murray; maybe Miami Ohio?). These bicycle parts may not have been good specimens for a pure restoration project, but I believe I can put some life back into the 90-year old bike. The bike is not especially rare or unique, as others have nicer projects, posted from time to time.
http://ratrodbikes.com/forum/index....motor-bike-built-by-pope-westfield-mfg.63301/
http://ratrodbikes.com/forum/index.php?threads/my-1930s-westfield-pope-build.57980/
http://thecabe.com/forum/threads/westfield-serial-numbers.98126/
Oct 5, 2015
526
490
The infamous “HTF” head badge.
Somehow, I eliminated some makes/models, and concluded that this bike is a yet unknown to me brand (other than non-Columbian) made by the Westfield Manufacturing Company. The missing head badge used two wide-apart fastener holes on the right and left sides of the head tube. Below those holes were another un-used set closer together filled with what looked like OEM paint.
I looked into the chain-ring, with 3 pumpkin holes plus 3 wedges and believe that besides being a Westfield (double-D) it looks somewhat similar in style to some TOC Rambler models.
Not mine: Earlier Jeffery & Gormully 3-arm Crank (spider)
Not mine: Later 180-out to accommodate a drive pin.
Oct 5, 2015
526
490
Interchangeability.
Through disassembly and parts checks, I found out some peculiarities (headset, bottom bracket).
The odd fork and headset – 26 TPI threads (versus 24) lightly cross-threaded on top, a 25.4 mm bottom race (versus 26 or 27), and odd bearings and cups. I plan to re-use the cones, and replace the cups and bearings with those from a standard 30 mm headset. The top bearing retainer and/or cup appear to have been replaced, at some time, perhaps with the wrong parts (small). Adapting a Raleigh 26 TPI loose ball headset might be an alternative.
The bottom bracket was not 24 TPI either, so I ordered an extra fine 28 TPI set, then after a closer look, (next to some pedal axles) found the crank threads to be coarse 20 TPI (or 1.25 mm). So the cones will be saved. Then, the cups were also small at 1-15/16” (not 2.03” interference fit), so the cups will be saved too. At least the new 12-bearing retainer sets may be used.
It took a propane torch to get the drive side cone off of the cranks, only to find the chain-wheel double-D shimmed for a tight fit – how long has that shim been there.
The bearing cone, nut and knurled washer appear to be the style that are sometimes associated with the Hendee "Indian style" - as are the chain tensioners also.
Oct 5, 2015
526
490
The wheels and tires came in, with considerable saving by using 622mm versus 635mm cladded with unobtainium. I ordered 5/16" x 90mm hubs, but USPS delivery was intercepted, twice. No more online ordering, for a while.
For the formerly plated since rusted items, I figured that some hammer-tone pewter might look good over the pitted metal. The stuff had some bad reviews and the hammered-effect works better on large flat surface areas. Basically it is a metallic dark gray, not pretending or trying to fool anyone that it looks anything near a chrome plate substitute; it is kind-of goopy, 7-days to 'dry' feels tacky, probably still wet underneath. Will also leave the aluminum rims and fenders in OEM state.
Found some pedals I like, (9/16" with extenders).
Some of the "reds" are in the fore-ground: Rustoleum Burgundy (center), Colonial and Regal reds (left/right). I like the Colonial color better (almost same), but chose the Regal, because it is the 1X version, which I will use over red primer. I believe that the nooks and crannies of a bike frame would make use of a 2X thicker paint more difficult.
Oct 5, 2015
526
490
More on chain-wheel and identification of brand.
Earlier I had found some 3-hole skip-tooth chain rings that were just not the same (nonpareil?). Another TOC model from Eclipse which would be better known later for their coaster brake hubs (as Bendix). TOC Eclipse Bicycle, Elmira NY (below):
Even Schwinn had a 3-hole design; 1939 Schwinn Paramount (below):
Through patience and further searches, I found (on eBay) some 1929 catalog pages for the Shapleigh Hardware Company of St. Louis MO. The catalog showed both a special truss fork and a three (3) hole chain wheel sprocket. So I now believe that my new 90-year old Westfield-built Motobike was most likely badged as a Shapleigh Motor Bike. Their catalog mentioned other “badges” such as Cyco, Diamond (edge), Nonpareil (french), Rugby, Wonder, and Vassar (college).
1929 "Shapleigh Special" Red/Blue/Brown Motor Bike
Oct 5, 2015
526
490
Head badges & progress report.
I found some nickel-brass head badges with the side-holes.
The incorrect “Columbia” does not quite fit either of the hole patterns.
The more appropriate “Shapleigh” badge does fit; the small fastening holes align fairly well.
Also, making some slow progress on the frame/fork (red).
Mar 5, 2014
1,360
2,563
Utah
3   0   0
Any final progress to report PF? Would love to see whatcha got done. Great looking bike BTW....:thumbsup:
Your fork looks like the one on the right...1922 or 23 Westfield Indian style as does this frame..
Pic fr:thecabe
Sep 13, 2021
5
9
Hello Phil,
I am hoping that you may be able to help me identify a bicycle. I believe that I may have a 1927 Shapleigh (Westfield) Diamond boy's bicycle. There are diamonds on either side of the model number, and the end of the pedals have a diamond shape to them. It has a 17" frame, 23" dia rims, and a 7-1/4" dia crank sprocket.
Although mine would be a 1927, I was wondering if it would match up with the information in your 1929 catalog... I haven't had any luck finding a 1927 catalog.
Thank you, Keith
Oct 5, 2015
526
490
@sthpawil Westfield supplied bicycles to many retail outfits. I have seen the diamond stamps before, but not aware of their significance.
A hardware store did have a slogan, "the diamond edge is a quality pledge" - (perhaps before they bought out the keen-kutter brand from E.C. Simmons).
Sep 13, 2021
5
9
Thank you Phil. On your older post, I thought you meant that you had purchased the 1929 Shapleigh ads. I was hoping to see a picture of the page that mentioned the Diamond badge. Regards, Keith
Oct 5, 2015
526
490
Well, they misspelled it on one of the pages.
I used to have other pages of unknown date indicating other badges which I have never heard of.
More on Diamonds:
Jun 6, 2011
100
101
7   0   0
Does anyone have pictures or info about the Vassar bike? I picked up an early frame recently that looks like it had a Vassar badge on it, but it has no other markings I can find
