Who has made a 1 1/8” steer tube fork work in a 1” head tube?
Oct 23, 2020
356
468
48
If anyone has figured it out, they likely reside here. I have another place to use it if it can’t be done.
Oct 18, 2008
1,266
187
Colorado
That headset is pretty slick! Lots of new things since I originally hung around here!
FWIW it fits "better quality" American head tubes like Schwinns.
If you have a (sorry) cheaper old department store frame that would normally use the Wald 4080 headset, you can likely just press in 1 1/8" cups. ;)
  • Like
Reactions: Captain Awesome
Jun 13, 2015
1,086
1,951
44
US occupied MA
1   0   0
I can't remember which brand I used on a Spaceliner, but it was a 32.5mm head tube ID like the Retro Ryder unit. Any smaller head tube ID than that and I don't think there's anything out there that works (though I imagine if someone could machine a headset with a fully external bearing race or maybe even a headset that pressed onto the OD of the head tube—as long as there's enough length beyond the top and down tubes—that could work).
Oct 21, 2008
1
7
I had my LBS use a head tube reamer to cut an 80’s Schwinn Cruiser head tube to fit a standard 1 1/8” headset. We measured A LOT to make sure there was enough material to make it work. I’m still running it today. I’m waiting to install a White Industries headset on the frame once the fork I want is back in stock.
Oct 23, 2020
356
468
48
As soon as I finish my monster bike, I will see what I can cobble together. I am almost thinking of going another direction with my triple fork that the head tube wouldn’t need modification (but there will be plenty of other mods).
May 20, 2009
6,508
4,886
Isle of Hope, GA
26   0   0
Saw someone on the Electra FB page, sorry can’t find the post, solve this by buying a piece of 1 1/8” headtube stock from eBay, cut ‘rings’ long enough to fit the larger cups and slid them over the top and bottom of the 1” headtube...the existing headtube kept everything level. Now, I’m in no way endorsing this, just passing on a ‘potential’ solution...
May 20, 2009
6,508
4,886
Isle of Hope, GA
26   0   0
Found the FB post
Captain Awesome
Lord of Irrelevance
Aug 9, 2012
2,405
3,697
Sunny SC coast
2   0   0
:39: :39: :39:
The Bike Wall BOXKARS
