Wood frame bicycle
Sep 26, 2012
1,503
2,533
Chicago, IL
1   0   0
This is cool. Never seen one before. Found it on the bike wall.
1896 apparently.
Someone on RRB should buy it and build it out so I can watch :bigsmile:
Listing here
https://www.ebay.com/itm/174422671918
Bonus ebay fun!
Checkout what the triathlon world thinks a "vintage" wheel looks like.
Vintage Three Spoke Rear Bicycle Wheel. $300
Yep late 90's to mid 2000's is now Vintage, hahaha! Silly kids.
When I was a little kid my grandma owned an Antique Store (That's now a Vintage Store to you kids) on Ventura Blvd in the San Fernando Valley, California. Needless to say, I've always been intrigued by old items. I asked her when I was 6-7 years old, Grandma how old does something have to be, to be considered an Antique? She replied, 50 years old minimum is rule of thumb for the most part in my store. Which makes sense, because in the early 70's most of her items were from the teens, 20's and older. To this day I still think that's a fair answer.
I think I remember hearing something similar. 50 years antique, 30 years retro, 20 years vintage.
Could have made it up though, the old brain is well past vintage.
I think it varies with the item. I was always told 100 years for an antique for things like furniture, but 25 for cars. Don't know where bicycles fall, but just from that small sample, it appears that it might depend upon the likelihood that the item will survive the term. Furniture traditionally built to last and existing indoors with good repairability and nearly no loss of utility over time (just loss of fashion, perhaps, but trends often return and furniture is also adaptable) more easily survives 100 years than an automobile. Of course, with the pace of change and move toward disposability and forced obsolescence for nearly every industry across all price ranges and the manufacturing of anything made to last generations becoming an increasingly niche market, I think the number of years that define the items in the respective categories may necessarily have to change. In some cases, like the automobile, the trend toward greater short term longevity has increased (the average age of the automobile on the road is about the highest it's ever been because 25 years is a much easier milestone to make before the cost of required maintenance exceeds or gets too close to modern replacement cost than it had been traditionally, especially in the corrosion areas thanks to better metal protection and resistant alloys), but the long term longevity has decreased. (While the average 1990-up car is more likely to make it 25 years than earlier cars, I would posit that it is far less likely to make it to 50. Their more numerous and specialized parts that change more frequently and the required repair knowledge of complicated systems get rarer and more expensive with age and largely negate the business case for reproduction parts that currently can be made for simpler older cars. That's assuming a world where the nostalgia for cars of one's youth still hold the same attraction and similar economic and environmental stability as today, but I don't want to turn this into a whole thing about cars and speculating on the future of a changing world, just illustrate that maybe what qualifies as antique, vintage, etc. has to be somewhat amorphous.)
@Couch tater
Does your chain look like the example you posted or more like this?
Scanned this work of art from The American Bicycle - Jay Pridmore and Jim Hurd.
Tonk's Old Hickory.
Bamboo Cycle Co., England - c.1897
@Couch tater
Tonk's Old Hickory.
My chain is exactly like the photo except the blocks are hollow on mine and have felt inserts to lube the chain. My bike is 1892 - 93. Here is an actual photo of my chain. I'm going to resume the restoration of it this winter.
It appears chains were slightly more refined in years after yours. Details are scarce. Vaguely remember a wide chain when you commented.
Thanks for linking your build thread.
1888 replica of a Whippet.
I got a fence made out of bike frames. I should take one and cut off the lugs and epoxy and screw wood or bamboo unto the cut off lugs to make a faux wood bike. I would not feel safe with a splinter cycle though. Bamboo with carbon fiber rods epoxied inside the bamboo would be my choice if using old cut off lugs.
The chain ring looks really thick. It must have carried a heavy, industrial chain.
Antique bicycles had massive skip tooth block chains. Replacements are custom made and costs 5 x a Walmart bicycle. 1900 side by side tandems had skip tooth chains that looked like they could be used for bulldozer treads, ha ha. I have pictures of massive skip tooth chains from an antique bicycle ride (must be older than 1920) on mackinaw Island, but I can’t locate them. The above picture of the skip tooth chain on the reproduction Whippet is a laminated block chain. The one with the felt inserts looks like an original made from solid blocks. No rollers on these. I have three bikes with skip tooth block chains, but only one is not laminated. Non laminated block chains took a lot more machining to make and I consider them the gold standard of skip tooth chains.
