3G Jemima + Nexus 3 using original spokes?
A spoke calculation is your best bet. But I have laced several Nexus 3-i hubs in place of a coaster using OG spokes. I have needed to purchase brass washers @ the home depot to pick-up some slack under the nipples as the Nexus tends to be a wee bit taller.
I hadn't run into the previous posters problem, recently!
Like was said, I also replace c.b. hubs with 3s all the time. As long as they're (hubs) within a 1/4" of diameter of each other I go for it.
Oh its not a problem, I just prefer NOT to grind run-outs.
It is perfectly acceptable to grind the excess off. In fact I was taught you had to or the spokes were short.
