Hello All!
I'm new to the site and have really learned a bunch already! I think I'm ready to tackle my first build. I want to convert a 1972 Typhoon to a 5 speed with derailleur. I'm going to be using some older mtn bike rims with 26X2.125 WW tires. The wheels fit in the dropouts with out much effort.
What I'm running into is that when I put the rear Mtn Bike wheel on the Typhoon frame, the wheel / tire is not centered in the frame. The gear cog makes it not symmetrical - meanining the hub and tire are not centered in the frame and the rear tire rubs one side of the frame. Do I need to install spacers on the axle (opposite the gear cog) to balance the space the gear cog takes up so the tire will be centered in the frame and not rub? Do the spacers need to equal what the gear cog takes up exactly or is it just a guesstimate on the spacers??
Also, will this additional "stretching" of the frame caused by adding the spacers casue problems? Any advice would be apprectiated.
Thanks,
RK
Thanks,
RK
