Yea, what he said.It might not be the cables. The shifter rotates a plastic shaft connected to three spring loaded cams that shifts the gears. You might want to take it apart to clean and grease everything.
This is what the 40+ year old grease looks like!
Thanks for sharing ill be taking this apart for sureIt might not be the cables. The shifter rotates a plastic shaft connected to three spring loaded cams that shifts the gears. You might want to take it apart to clean and grease everything.
