Hi all
Here in the UK historically we have never built many bikes with curves in the frames [ unlike the beauties you have access to in the USA & Australia ].
So when it comes to hacking , the frame shapes I get access to are limited in geometry are boring and need some help to look good.
I built a simple chopper with a couple of hacks to a ladies brazed lugged frame , I added 2 foot to the forks and cut rear end from the frame and added 9" and a small curve to the chain stays and then some new seat stays to give cantilever brakes on the rear.
image hosting 30 mb
Now that bike has a few issues and I want to do something different to the next one.
I have an almost identical frame and wondered if this would work ?
image hosting over 10mb
I now have a hydraulic bender so wanted to cut the frame at points B and try to bend the bottom tube between points A to allow the head tube to become more vertical and the forks to be a bit shorter and reduce the trail which on the old bike is about 8"+.
I would then bend a matching [ ] tube to join parts B back together.
One of the other problems with the old bike is inseam length to solve that I will cut the frame at E and add about 4-5" in there then cut the rear end off adding about 10" of tubing at C and attach some new seat stays to give cantilever brakes on the rear again.
So will I be able to bend the tube ? and what will it look like when I do ?
regards paul
image hosting 30 mb
regards paul
