I'm building a defferental for a trike rearend.
This was built using off the shelf parts and home power/hand tools
has a two scooter freewheels with axle adapters seperated by a section of tailpipe and bolted together(6mm bolts) two 4 bolt sprockets are bolted on in line with the front hub whick I added sprockets to(brazing)
This lets both axles pull but during corrning the outside wheel will be able to rotate faster for correct tracking.(inside does the pulling)Only one chain is required to operate the Deffer but I plan on using this for a two person velocar so I added the second chain for strength/and a 6 speed freewheel block will be added to the hub
