Personally, I wouldn't use conduit. Just seems too cheesy to me. If you have a metal supply store in your city, then go for
welded steel tubing.
Chopper bikes certainly don't need to be Chromoly as they typically aren't jumped or stressed out like BMX bikes.
I am currently working with a friend on stretching a 20" Orange County Chopper as it no longer fits a growing 13 year old's legs.
This bike uses 1-3/4" tubing for most of the frame, and an oval section at the bottom. The steel tubing we are using is
16 gauge, which is 0.0598.
Plenty hefty, but again, we are stretching this bike by means of splicing - not replacing entire frame sections.
We ended up making custom "insert sleeves" to reinforce the spliced areas, which worked very well. These are simply longer sections of the same 1-3/4" tubing, split length-wise with a section removed and then rewelded to fit snugly. The "cosmetic" outer sleeve slips over the top. The longer ends of the splice pieces are then slid inside the open tubing ends where we made our frame cuts. Viola! Instant stretch!
We also drilled (4) 3/8" holes around every cut portion of the frame tube so that we could weld the inner splice pieces to the original frame tubes. This method ties everything together nice and strong. To hold everything in relative position for welding, we used sheet metal scews.
It would have been far easier to use insert sleeve material that slips tightly
inside the cosmetic outer tube pieces, but the metal supply store was out of this particular size of tubing when we really needed it
The final, stretched and welded frame is then ground, and smoothed with body filler. The tighter you can get your metalwork and welds the less filler that's needed. :wink:
