Okay, so after i put my back tire back on after painting my frame, my chain wont stay tightened like I wanted it. It keeps getting loose. Now my chain keeps coming off and locking up my sprocket..... HELP!
clamdigger said:Consider Wald 318 rear axle washers.
axsepul said:Sounds like your washers are slipping on your new paint because they are worn out. They should have a diamond cut area which will grab on to the frame. Follow this guys advice or remove the washer from another bike.
gcrank1 said:Consider what they do and the clamp down effect. You gotta keep the chainline pretty close in this, but I prefer a washer on each side of the dropout. Ive run a thinnish flat (no aggressive surface) on the inside with the agr. one under the outer nut with success. Just having the inner nut surface as a clamp point against the dropout never seemed like enough to me.
