Hey guys coming to you for some more advice. I put a set of Hoggy-G's 24x3.45 on the 57mm rims. I have no frame clearence problemS and the fenders even fit!! My only problem is the chain is rubbing, WHAT TO DO?? I was thinking I would have to remove the crank arm and put some washers behind it but is there any other way?? It is only a fraction of an inch, when the tires not torqued down there is no problem but once I tighten it, it starts to rub..
Thanks Guys
Thanks Guys
