If no obvious problems demand forewarnings, here's my rough plan:
Want to cut the frame to a stub just tall enough for seatpost clamp.
Then want to cut a long U down the back to clear the layback brace.
Already a small thin U cut there, else the post clamp wouldn't work.
Fortunately lots of "RatRod" gusset on the front side of this area.
Also grind and narrow sides of the brace weld where it must now slide
into the frame. Maybe braze some extra fillet top and bottom instead?
Picture doesn't do a great job of showing the weld interference problem.
Finally, clamp the frame-top stub through the eye of the layback brace.
Problem here seems the slight difference between 25mm and 1inch.
Tempted to abuse a beer can instead of masking tape for the shim.
Maybe a can of tin plated steel would be less galvanic vs my frame?
Turn and stop lights now have to go somewhere else. Back of seat or rear fender?
Ammo box battery paneer (not yet installed) another place light cluster might go.
