Scored some glorious roadkill today (pictures later; it's miserable out). 26x4 fat single-speed MTB. Disc brake ready with only a couple parts missing (rear brake looks perfect, front lever, cable, and hardware other than the disc are MIA). Everything on it still looks to be in the correct shape, and tires are filthy but have plenty of tread. Frame has some brands I've never heard of on it along with an assortment of stickers, BUT this may be the (budget-cost) base I've been looking for to turn into a (mostly) weather-proof winter bike.
HOWEVER
Can't be weather-resistant to my satisfaction while it's still got a chain instead of a belt drive (an elegant drivetrain, for a more civilized age), and ideally I'm going to want an internal gear hub in that beastly rear wheel.
What is the actual difference between horizontal rear dropouts and "track end" dropouts, if any? It seems to be a steel frame, so welding shouldn't be a problem. I have a local welder I've worked with for my drift trike before (I have no interest in doing any welding myself, despite how easy some people say it is; it's just not for me), but I want to bring him as much of the homework already done as possible. Should I be looking for a junker frame, and transplant the entire section (end of the 'triangle' that extends away from the rear dropouts), or is it better to fill and flatten the existing vertical dropout structure, then cut and grind out the proper opening? Planning on using Surly Tuggnuts when all is said and done.
What is the difference between MIG, TIG, and brazing?
Can the original disc brake mounts be preserved, or should I be looking for tabs from a site like Frame Builder Supply?
Advice, accounts of similar projects, and/or general measurements are all welcome. Thanks in advance! I'll add photos to this thread tomorrow, if the sun decides to return.
HOWEVER
