Bicycle808 said:
There's no such thing as disk or rim brake levers; there's just long-pull (v-brakes, most discs) and short-pull (road brakes, centerpulls, canti's, u-brakes, "road" discs, drum/roller brakes.)
You want short pull.
True, but from what I've seen, most sellers don't advertise levers as "short pull" or "long pull", but use the terms "V brake" or "canti" (etc), instead, so it helps to understand the difference.
If you do an Ebay search for using the terms "short pull" or "long pull" brake levers, hardly anything comes up. Search for "canti", "cantilever", or "V brake" lever, and you'll get a MUCH larger list.
One last note, V brake levers are referred to as "linear", quite often.
