Hi !
Here is an ease way to modify a regular shifter into a stylish shifter ..
Note
mine is horizontal to have the look of a automatic 40s style shifter , but it can work in all angles)
Just start with any regular lever shifter like this (they are pretty much all the same)
- remove the rubber part at the end
- find a chrome piece of pipe that don't quite fit over the end but is very close
-hammer the pipe into a square"or the shape of the lever" and grind or file the lever a litle bit at the time untill you can hammer the pipe on to it "very snug" so you don't have to drill and screw it in place
-find or make some sort of handle/knob for the end of it
-then make a little arrow in thin sheet metal "painted red" and fasten it on the lever/pipe (mine have screw on the lever that i used for this)
-the cut a circle in anything (mine is plastic jar top) and paint it or add a sticker like i did so you have a good font to add the speed notches/numbers
and it should look like this ..or better..or not![Stick Out Tongue :p :p](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
ill instal this cadilac shifter on my trike moon bars soon
can't wait to finish it :!:
Note
![BeeKay_Trike_Shifter_1.jpg](https://proxy.imagearchive.com/ebd/ebdaee1c6b51c5a1e0682f5658b9fdfb.jpg)
![DSCN4658.jpg](https://proxy.imagearchive.com/cc4/cc44463c207a519820c0e2a7361c0089.jpg)
![DSCN4657.jpg](https://proxy.imagearchive.com/e34/e3488cf1630faff9d3e342828df517b0.jpg)
![DSCN4656.jpg](https://proxy.imagearchive.com/ea0/ea087a7f1b5c079f685c4808ab2ca443.jpg)
![DSCN4654.jpg](https://proxy.imagearchive.com/864/8644943dba059933a24fd213db2ab07e.jpg)
![DSCN4653.jpg](https://proxy.imagearchive.com/b71/b71f20a2b79e1bc9b418ed38b82e6f4f.jpg)
