Finally some progress today!
Started by welding the diff brace to the axle tubes:
Then moved on to the headtube, extended it with some tubing from the frame of a MADD bmx:
Then on to the forks, extended the headtube with some 21mm thick wall pipe and then got ready to weld them to the mini bike legs:
Filled the gaps under the fork crown with bits of steel washers cut to size:
Used the rest of the washers on the top:
So now I have the front and rear ends done, I can work on joining them somehow... I have a few ideas...
