Last Saturday I started cleaning up the old Elgin that I acquired back in January. When I took the front wheel off, it required a 15mm socket to get the axle nuts off. The bearing cone also required the 15mm socket. Has anyone else experienced this anomaly? All the other nuts and bolts on the bike are SAE. I had another front axle so I thought that I'd just use it so everything on the bike would be SAE. But I quickly found out that the front axle bearing retainer has about half the bearings but each ball is twice as large as standard bearings. Did Elgin do anything weird in the late 30's or early 40's?
Thanks in advance for any insights.
Ed
Ed
