I am restoring an old Schwinn Breeze for a co-worker, and am in the reassembly stage. I successfully re built the front wheel and had to get a new axle for her as the original (stamped!) was bent. The new axle I got is threaded all the way across, if that matters. I put it all together
(outside bolt > washer> skinny (lock?) nut > cone nut > bearings > hub/axle < bearings < cone nut < skinny (lock?) nut < washer < outside bolt)
, but when I rotate the wheel in any direction, it either loosesns or tightens as it spins. What am I missing/doing wrong? I can post a picture later, when I get home.
