Definitely like the black tires better on this than the white ones. Has a 'tougher' look to it now. If you had a really bright ( chrome, silver ) chain, I would paint the chain guard black so it would set off the chain even more. Like a backdrop.
They sure can headbutt! I did google the English word and came out at "Stone Marten" but could not believe that was the right translation, so I dismissed it.Those Strongarm coaster arms look cool.
I had to look up what a "steenmarter" was. In English they are called stone martens. And sure enough, the google image results showed multiple pics fo them chewing on engine components. Maybe you should train the baby goats to hunt them down and headbutt them.
I totally agree on the tougher look! It just fits a chopper bike.Definitely like the black tires better on this than the white ones. Has a 'tougher' look to it now. If you had a really bright ( chrome, silver ) chain, I would paint the chain guard black so it would set off the chain even more. Like a backdrop.
"Strong to the finishGreat work on the brake ARM. You could paint the anchor tattoo on the forearm section like Popeye.
I thought about that, I like your creativity on mixed parts! And thanks!"The inner diameter of the front fork is 29mm, so maybe a bit too large for stem caps. 1 1/8" forks have and inner diameter of 25.4 generally."
In order to make it work on the Felt fork I had to buy 1 1/4" stem caps and star nuts instead of 1 1/8". I also had to use some short tubing cut from the Felt chopper bars that go into the fork tubing.
I love that coaster brake arm!
Thank you sir!"Strong to the finish
Cuz I eats my spinach!"
It's looking good, Bart. Really good
Thanks OJ, I agreed with you at first sight. But then it would not be aligned with the frame. But I will check that and take a picture. Is your view changed after seeing the pictures below?Diggin' da choppa BRE! I like the 'flipped' chain guard. Can you raise up the back end of it so it sits parallel to the bottom run of the chain? I think that would finish it off nicely!
RaT oN~!
I love the simplicity of the rod brakes. And it quite simple to replace, even when tire and rubber patch are worn out.It's all coming together so well!
Love the peek of the coaster brake ARM in the wheel.
I've always wanted to try and incorporate some rod brake parts into a build someday. I have a couple of old scrap Raleighs that I could pull the parts from.
I know OJ, I'll try this position soon. Thank you!My opinion hasn't changed.The chainguard , laying on the frame like it is, still detracts from the overall look; in my opinion.
But it's not MY bike.
Always appreciate your input Toro!I think your chain is too tight and it might be the reason why you have problems with the rear cog.
Otherwise I love it, the Nirve choppers frames have such beautiful lines. The brake lever is perfect for these handlebars!
The roller brake might need more adjustment. I have set up my rear roller brake with only 5-6 mm pull on the cable for it to grab. On the pic there is no pull on the cable:
Do you know the Mosselman? He comes from Scheveningen:dig the coaster brake arm. Musselman approved.
When I am able to take a picture before dark, I will certainly do that!Dig the chainguard position! Give us a pulled back photo of the profile from the drive side, just to get the whole picture.
Register today and take advantage of membership benefits.
