Owner & Founder
This is one of those maintenance techniques that I have never mastered and has always frustrated me. :x
It seems that when I try to adjust and set up a caliper brake on a bike I never get them to work correctly. The side that had the brake cable threaded through always seems to stick in towards the rim after the brake lever is released. I've tightened the main mounting bolt that holds the brakes to the bridge and that usually makes the caliper arms stick even worse. That has made me think that you shouldn't over tighten this bolt.
Is there some trick to getting both caliper arms to tighten down when you press the brake lever and then release freely when the lever is released? Is it because it's old technology and I'm too used to how well the newer cantilever brakes work?
The set I happen to be dealing with at the moment are a set of Dia Compes on this old GT.
I have installed a new brake cable and just can't get the brake caliper to work correctly.
![DSC_0012.jpg](https://proxy.imagearchive.com/ffb/ffbef10d3b4a8e2ac6074820bf4209ed.jpg)
